Control Surface - More than 8 Buttons required
Hello,
I use the wonderful "Control Surface" software to create midi controllers and everything works fine so far. But now I have a module that needs more than eight buttons and I don't know how to do that. So far, based on the following example from the Control Surface website:
Control Surface: CCButton.ino, I have adapted the programmes by copying and adapting the text lines according to the required number of buttons.
#include <Control_Surface.h> // Include the Control Surface library
// Instantiate a MIDI over USB interface.
USBMIDI_Interface midi;
// Instantiate a CCButton object
CCButton button {
  // Push button on pin 5:
  5,
  // General Purpose Controller #1 on MIDI channel 1:
  {MIDI_CC::General_Purpose_Controller_1, CHANNEL_1},
  Control_Surface.begin(); // Initialize Control Surface
  Control_Surface.loop(); // Update the Control Surface
However, this no longer works for more than eight buttons because there are not more than eight General_Purpose_Controller_x. I think that this should generally be done differently, perhaps with an array? However, my knowledge is not such that I can cope with this alone.
I would be grateful for any help.
Here is my current source code for four buttons:
CCButton button1{
 6,
CCButton button2{
 7,
 //General Purpose Controller #1 on MIDI channel 1:
 {MIDI_CC::General_Purpose_Controller_2, CHANNEL_1},
CCButton button3{
 8,
{MIDI_CC::General_Purpose_Controller_3, CHANNEL_1},
CCButton button4{
 9,
 {MIDI_CC::General_Purpose_Controller_4, CHANNEL_1},
// Instantiate a CCPotentiometer object
//CCPotentiometer potentiometer1 {
  //A0,                                   // Analog pin connected to potentiometer
  //{26, CHANNEL_9}, // Channel volume of channel 1
//CCPotentiometer potentiometer2 {
  //A1,                                   // Analog pin connected to potentiometer
  //{27, CHANNEL_10}, // Channel volume of channel 1
// Instantiate an analog multiplexer
//CD74HC4051 mux {
  //A2,       // Analog input pin
  //{10, 11, 12} // Address pins S0, S1, S2
// Create an array of potentiometers that send out
// MIDI Control Change messages when you turn the
// potentiometers connected to the eight input pins of
// the multiplexer MIDIAddress myAddress = 16;
//CCPotentiometer volumePotentiometers[] {
  //{mux.pin(0), {1 , CHANNEL_1}},
  //{mux.pin(1), {2 , CHANNEL_2}},
  //{mux.pin(2), {3 , CHANNEL_3}},
  //{mux.pin(3), {4 , CHANNEL_4}},
  //{mux.pin(4), {5 , CHANNEL_5}},
  //{mux.pin(5), {6 , CHANNEL_6}},
  //{mux.pin(6), {7 , CHANNEL_7}},
  //{mux.pin(7), {8 , CHANNEL_8}},
See Problem using more than 8 MIDI_CC::General_Purpose_Controller on Leonardo · tttapa/Control-Surface · Discussion #822 · GitHub and Please implement the undefined CC numbers · Issue #424 · tttapa/Control-Surface · GitHub.
Indeed, see Control Surface: Getting Started and Control Surface: Multiple-Control-Change-Potentiometers.ino for some examples of defining such an array.
Thank you very much for the quick feedback Pieter. I helped myself with this link from your message: Please implement the undefined CC numbers · Issue #424 · tttapa/Control-Surface · GitHub. You first have to realise that just the number is enough, great.
Everything about your Control Surface work is so well thought out and consistent. From the software itself, to the outstandiny documentation, the examples and the support. I can only take my hat off.
