Hello! I have used the example above to run two multiplexers.
My problem is, that both multiplexers seem to share the same channels.
When I try to name the channels beyond 16, it says channel was not declared.
what should i do, here?
Thanks!
#include <Control_Surface.h>
//USBMIDI_Interface midi;
HairlessMIDI_Interface midi;
//StreamDebugMIDI_Interface;
//CCPotentiometer pot = { A0, MIDI_CC::General_Purpose_Controller_1 };
CD74HC4067 mux = { A0, {3, 4, 5, 6, } };
CD74HC4067 mux2 = { A1, {3, 4, 5, 6, } };
CCPotentiometer volumePotentiometers[] = {
//{ mux.pin(0), {MIDI_CC::Channel_Volume, CHANNEL_1} },
//{ mux.pin(1), {MIDI_CC::Channel_Volume, CHANNEL_2} },
//{ mux.pin(2), {MIDI_CC::Channel_Volume, CHANNEL_3} },
//{ mux.pin(3), {MIDI_CC::Channel_Volume, CHANNEL_4} },
//{ mux.pin(4), {MIDI_CC::Channel_Volume, CHANNEL_5} },
//{ mux.pin(5), {MIDI_CC::Channel_Volume, CHANNEL_6} },
//{ mux.pin(6), {MIDI_CC::Channel_Volume, CHANNEL_7} },
//{ mux.pin(7), {MIDI_CC::Channel_Volume, CHANNEL_8} },
//{ mux.pin(8), {MIDI_CC::Channel_Volume, CHANNEL_9} },
//{ mux.pin(9), {MIDI_CC::Channel_Volume, CHANNEL_10} },
//{ mux.pin(10), {MIDI_CC::Channel_Volume, CHANNEL_11} },
//{ mux.pin(11), {MIDI_CC::Channel_Volume, CHANNEL_12} },
//{ mux.pin(12), {MIDI_CC::Channel_Volume, CHANNEL_13} },
//{ mux.pin(13), {MIDI_CC::Channel_Volume, CHANNEL_14} },
//{ mux.pin(14), {MIDI_CC::Channel_Volume, CHANNEL_15} },
//{ mux.pin(15), {MIDI_CC::Channel_Volume, CHANNEL_16} },
{ mux2.pin(0), {MIDI_CC::Channel_Volume, CHANNEL_17} },
//{ mux2.pin(1), {MIDI_CC::Channel_Volume, CHANNEL_18} },
//{ mux2.pin(2), {MIDI_CC::Channel_Volume, CHANNEL_19} },
//{ mux2.pin(3), {MIDI_CC::Channel_Volume, CHANNEL_20} },
//{ mux2.pin(4), {MIDI_CC::Channel_Volume, CHANNEL_21} },
//{ mux2.pin(5), {MIDI_CC::Channel_Volume, CHANNEL_22} },
//{ mux2.pin(6), {MIDI_CC::Channel_Volume, CHANNEL_23} },
//{ mux2.pin(7), {MIDI_CC::Channel_Volume, CHANNEL_24} },
//{ mux2.pin(8), {MIDI_CC::Channel_Volume, CHANNEL_25} },
//{ mux2.pin(9), {MIDI_CC::Channel_Volume, CHANNEL_26} },
//{ mux2.pin(10), {MIDI_CC::Channel_Volume, CHANNEL_27} },
//{ mux2.pin(11), {MIDI_CC::Channel_Volume, CHANNEL_28} },
//{ mux2.pin(12), {MIDI_CC::Channel_Volume, CHANNEL_29} },
//{ mux2.pin(13), {MIDI_CC::Channel_Volume, CHANNEL_30} },
//{ mux2.pin(14), {MIDI_CC::Channel_Volume, CHANNEL_31} },
//{ mux2.pin(15), {MIDI_CC::Channel_Volume, CHANNEL_32} },
//constexpr analog_t maximumValue = 16383 - 255;
Control_Surface.begin();
void loop() { Control_Surface.loop(); }
