Hi everyone,
I recently got an Arduino UNO kit and started to learn how to use it into my project.
My idea is to build a speaker whose volume can be controlled by Photocells.
Ex: There are total 4 photocells and each one represents one level of volume.
So, if photocell #1 detects the light under Min light, it will increase one level of the volume, and so on..
I bought a portable speaker which has line-in and can read music sources from laptop or cellphone. And I took its power supply's wire connecting to the Arduino.
I was thinking to parallel different resistors with the speaker, so that I can have different levels of volume.
But it didn't really work...
So, can anyone give me some suggestions or maybe tutorials about how to change volume of a speaker...
And here's my code...
const int aSensorPin = A0; // a (photocell) anallog pin A0
const int bSensorPin = A1; // b (photocell) anallog pin A1
const int cSensorPin = A2; // c (photocell) anallog pin A2
const int xSensorPin = A3; // x (photocell) anallog pin A3
int aSensorVal = 0; // photocell variable
int bSensorVal = 0;
int cSensorVal = 0;
int xSensorVal = 0;
int minLight = 380; //
int dSpeakerPin = 10;
int eSpeakerPin = 11;
int fSpeakerPin = 12;
for(int pinNumber = 10; pinNumber<13; pinNumber++){
pinMode(pinNumber,OUTPUT);
digitalWrite(pinNumber, LOW);
void loop(){
// Serial Port
aSensorVal = analogRead(aSensorPin);
delay(5);
bSensorVal = analogRead(bSensorPin);
delay(5);
cSensorVal = analogRead(cSensorPin);
delay(5);
xSensorVal = analogRead(xSensorPin);
delay(5);
Serial.print("raw sensor Values \t a: ");
Serial.print(aSensorVal);
Serial.print("\t b: ");
Serial.print(bSensorVal);
Serial.print("\t c: ");
Serial.print(cSensorVal);
Serial.print("\t x: ");
Serial.println(xSensorVal);
// 1.a:x b:x c:x x:o
if (aSensorVal > minLight && bSensorVal > minLight && cSensorVal > minLight && xSensorVal < minLight) {
digitalWrite(10, LOW); // turn off
digitalWrite(11, LOW);
digitalWrite(12, LOW);
}// 2.a:o b:x c:x x:o
else if (aSensorVal < minLight && bSensorVal > minLight && cSensorVal > minLight && xSensorVal < minLight) {
digitalWrite(10, HIGH); // turn on pin12
digitalWrite(11, HIGH);
digitalWrite(12, HIGH);
}// 3.a:x b:o c:x x:o
else if (aSensorVal > minLight && bSensorVal < minLight && cSensorVal > minLight && xSensorVal < minLight) {
}// 4.a:x b:x c:o x:o
else if (aSensorVal > minLight && bSensorVal > minLight && cSensorVal < minLight && xSensorVal < minLight) {
}// 5.a:o b:o c:x x:o
else if (aSensorVal < minLight && bSensorVal < minLight && cSensorVal > minLight && xSensorVal < minLight) {
digitalWrite(10, HIGH); // turn on pin11
}// 6.a:o b:x c:o x:o
else if (aSensorVal < minLight && bSensorVal > minLight && cSensorVal < minLight && xSensorVal < minLight) {
}// 7.a:x b:o c:o x:o
else if (aSensorVal > minLight && bSensorVal < minLight && cSensorVal < minLight && xSensorVal < minLight) {
}// 8.a:o b:o c:o x:o
else if (aSensorVal < minLight && bSensorVal < minLight && cSensorVal < minLight && xSensorVal < minLight) {
digitalWrite(10, HIGH); // turn on pin10
}// 9.a:o b:o c:o x:x
else if (aSensorVal < minLight && bSensorVal < minLight && cSensorVal < minLight && xSensorVal > minLight) {
digitalWrite(10, LOW); // turn on pin12
}// 10.a:o b:o c:x x:x
else if (aSensorVal < minLight && bSensorVal < minLight && cSensorVal > minLight && xSensorVal > minLight) {
}// 11.a:o b:x c:o x:x
else if (aSensorVal < minLight && bSensorVal > minLight && cSensorVal < minLight && xSensorVal > minLight) {
}// 12.a:x b:o c:o x:x
else if (aSensorVal > minLight && bSensorVal < minLight && cSensorVal < minLight && xSensorVal > minLight) {
}// 13.a:o b:x c:x x:x
else if (aSensorVal < minLight && bSensorVal > minLight && cSensorVal > minLight && xSensorVal > minLight) {
}// 14.a:x b:o c:x x:x
else if (aSensorVal > minLight && bSensorVal < minLight && cSensorVal > minLight && xSensorVal > minLight) {
}// 15.a:x b:x c:o x:x
else if (aSensorVal > minLight && bSensorVal > minLight && cSensorVal < minLight && xSensorVal > minLight) {
}// 16.a:x b:x c:x x:x
else if (aSensorVal > minLight && bSensorVal > minLight && cSensorVal > minLight && xSensorVal > minLight) {
delay(100);
