Controlling 16 LED's with two 74HC595 Shift register
Hello,
I am trying to controll 16 LED's light using TWO 74HC595 shift registers. (see schematic in attachment).
I am trying to run a simple program in a loop that would turn all the light OFF at the same time and then turn them back on (still in unisome).
Now, when I run my program, this is the result I am getting:
The first 8 light would go off.
The next 8 would go off.
Then the first 8 light would go ON,
The next 8 lights would go ON.
And son on ....
Can anyone please tell me what I am doing wrong.
int clockPin = 11;
int latchPin = 8;
int dataPin =12;
byte LED1 = 0b1111111111111111;
byte LED2 = 0b0000000000000000;
void setup (){
  pinMode (clockPin, OUTPUT);
  pinMode (latchPin, OUTPUT);
  pinMode (dataPin, OUTPUT);
void loop (){
  digitalWrite (latchPin, LOW);
  shiftOut (dataPin, clockPin, MSBFIRST, LED1);
  digitalWrite (latchPin, HIGH);
  delay (1000);
  shiftOut (dataPin, clockPin, MSBFIRST, LED2);
  delay (1000);
Hello,
A byte is 8 bits
Explaination of what your code is doing :
Send 11111111 to the first 595
Delay
Send 00000000 to the first 595, so the second 595 will be 11111111 (as all 8 bits of the first 595 were shifted into the second)
Delay
Send 11111111 to the first 595, so the second 595 will be 00000000 (as all 8 bits of the first 595 were shifted into the second)
etc...
Solution :
You have to change the data type to a 16 bits type (uint16_t), and call shiftOut twice, each with half the bits of your 16 bits of data
uint16_t LED1 = 0b1111111111111111;
shiftOut(dataPin, clockPin, MSBFIRST, LED1 >> 8);
shiftOut(dataPin, clockPin, MSBFIRST, LED1);
The compiler should have warned you about this. If it didn't, go to your Arduino IDE preferences right now and enable all warnings.
warning: large integer implicitly truncated to unsigned type [-Woverflow]
Pieter
PieterP:
Pieter
Hello Pieter,
Actually, I got that warning.
But after changing the code, I am getting this error:
exit status 1
'unit16_t' does not name a type
Not unit16_t but uint16_t, as in unsigned integer of 16 bits :slight_smile:
You may want to try this little library: GitHub - bildr-org/Shift-Register-8-Bit-74HC595: Arduino code to control the 74HC595 8-bit Shift-Register
guix:
You are the best.
Thank you so much
guix:
Delay
Delay
etc...
Solution :
Hello Quix
If I added a third 74HC595 to control an additional 8 LEDs to make it 24 LEDs in total, can I modify the code as below:
uint32_t LED1 = 0b1111111111111111;
Check the lengths of your right shifts.
As AWOL said (but you probably didn't understand), you have to right shift ( >> ) the correct amount of bits
//                XWVUTSRQPONMLKJIHGFEDCBA
uint32_t LED1 = 0b111111111111111111111111;
shiftOut(dataPin, clockPin, MSBFIRST, LED1 >> 16); // send bits X-Q
shiftOut(dataPin, clockPin, MSBFIRST, LED1 >> 8);  // send bits P-I
shiftOut(dataPin, clockPin, MSBFIRST, LED1);       // send bits H-A
Add 0.1uF caps from the '595 VCC pins to Gnd.
I don't see pin 9 from one chip going to 14 on the other, that is needed to pass the data from device to device.
