I will be working with 8 42"(approximately), common anode, RGB LED strips. Each will preferably be controlled independently in respect to color, brightness, and timing (on/off and perhaps fade), initialized by some kind of sensor. Likely a PIR.
I understand I will need 24 PWM channels. I have two Unos, and I don't mind obtaining a Mega 2560. I'm curious as to whether this is an appropriate product to make this work:
Would two of those and an Uno, or one of those and a Mega be an appropriate base for this project?
I'm hoping for some insight so I can start prototyping simple things and build up. Any links or comments would be appreciated.
I've done a bunch of reading on these strips this morning. Seems like it is a solid way to go as long as I can figure out the code.
Considering that I want 8 individually addressed light sections, is the NeoPixel option easier since I'm new to coding? The wiring would be incredibly simple. I don't know enough about the code to say which would be more approachable.
It does appear that for the amount of LEDs I would use, I need to step up to a Mega for the additional SRAM.
You only need one pin to drive a neopixel strip.
Also needed is 0 volts an +5 volts.
Each pixel needs three bytes of RAM.
Color is very easy.
You can set any number of pixels on and set the intensity and Color of each.
Adafruit has a library:
