Hello everyone!
I am bran new to the world of Arduino and was wondering if someone could possibly point me in the right direction. (Not do all the work for me
So my goal is to control knobs/pots on analog musical hardware with a standard expression pedal/ usually a 10k pot.
Basically a simpler version of this project that never got of the ground.
I dont need the midi control over the knobs, just expression/CV
https://www.kickstarter.com/projects/geckotool/geckotool-total-control-over-your-music-gear/description
Any advice is greatly appreciated.
Excited to start using Arduino!
If the knobs don't require too much force or too wide a range of movement then a hobby servo should be able to turn it without problem. A hobby servo usually comes with a variety of arms (sometimes called horns or bell-cranks) that attach to the output shaft (the shaft is usually splined or sometimes square). It should not be hard to 3D-print an adapter that replaces the knob and has a recess in the top into which one of the arms will fit. You then need a way to support the servo with it's shaft over the knob shaft at the right hight to engage the arm with the adapter.
If you know someone with a 3D printer of sufficient resolution you can print an adapter that fits the servo shaft and the knob shaft, thus eliminating the servo arm.
Time travel. About 50-years ago the remotes for TVs would run a motor that changed the channel or volume control.
You could just replace the pot with a Digital Potentiometer.
In addition to the shaft adapter (assuming a rotary pot!), you also have to secure the servo so it doesn't rotate.
Paul
SteveMann:
Very cool!
I will keep this in mind for the future.
I'm really looking to make this a quick swap; pop on and off kind of thing, but I like this as a possibility.
