Controlling a Servo With Ultrasonic Sensor Signal Using Arduino Code not working
Hello I'm new to this and found a project online. I put it together and pasted in the code. I get an error message saying Compilation error: #include expects "FILENAME" or It doesn't say what file should go next to it in the source material, here is the code.
#include
Servo myservo; // create servo object to control a servo
const int trigPin = 2;
const int echoPin = 4;
// initialize serial communication:
myservo.attach(9); // attaches the servo on pin 9 to the servo object
// and the distance result in centimeters:
long duration, cm;
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(20);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
// the condition for the distance
if ( cm > 7 && cm < 14)
myservo.write(140); // sets the servo position according to the scaled value
delay(4000);
else if ( cm < 8)
myservo.write(40); // sets the servo position according to the scaled value
delay(100);
delay(100);
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToCentimeters(long microseconds) {
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
Any help would be much appreciated!
Welcome to the forum
What should go after the #include statement is the name of the file that you want to include in the sketch
My guess would be that the line should be
#include <Servo.h>
as the code uses the Servo library
Please post a link to the project
Thank you for responding, that helped and fixed that issue. the link to the website is here https://www.instructables.com/Controlling-a-Servo-With-Ultrasonic-Sensor-Signal-/
