I want to control servo with ultrasonic sensor that when ultrasonic sensor detect something then servo keep running for 1 minute. this is my code
#include <Servo.h>
#define trigPin 12
#define echoPin 11
Servo servo0;
int pos = 70;
int sound = 250;
int i = 0;
int sens;
// Variables will change:
//int servo0 = LOW;
unsigned long previousMillis = 0;
const long interval = 10000;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
servo0.attach(9);
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) / 29.1;
if (currentMillis - previousMillis >= interval)
if (distance < 69)
Serial.println("the distance is less than 69");
for (pos = 70; pos <= 120; pos += 1)
// in steps of 1 degree
servo0.write(pos);
delay(20);
for (pos = 120; pos >= 70; pos -= 1)
servo0.write(pos);
delay(20);
servo0.write(70);
Serial.print(distance);
Serial.println(" cm");
if (distance = 90 || distance <= 90)
Serial.println("The distance is 90");
//delay(9);
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
On this occasion I have added them for you and have also Auto formatted the code in the IDE
What do you mean
What should the servo do during the minute ?
What does the sketch do now ?
not doing anything now..!
Does the servo work if you run the Sweep example ?
It should run for one minute once detected by ultrasonic
Do you see any output on the Serial monitor ?
What is the significance of the 10 second period timer ?
Where in the code is the 1 minute time period implemented ?
I note that you have a for loop of 50 steps, each of which takes 20 milliseconds and you do it twice which could mess up your overall timing if you do it wrong
Then the value of distance is never less than 69
Print the value of distance immediately after you calculate it. What values do you get ?
Also, I see this error in your code which will set distance to 90 rather than comparing it with 90
You still haven't said what the servo is supposed to be doing for a whole minute. Servos generally go from one position to another position and it takes a lot less than a minute.
Steve
It should rotate from 70 to 120 and 120 to 70 for one minute
Feedback please on the value of distance when it is measured, fix the bug that I noted and explain how you think the timing works in the sketch
That's the actual code. In this code the servo is rotated once by detecting any object by ultrasonic. and I want to rotate the servo from max to max time once detected through ultrasonic.
#include <Servo.h>
#define trigPin 12
#define echoPin 11
Servo servo0;
int pos = 70;
int sound = 250;
int i = 0;
int sens;
servo0.attach(9);
void loop(){
distance = (duration/2) / 29.1;
if (distance < 69) {
for (pos = 70; pos <= 120; pos += 1) {
servo0.write(pos);
delay(20);
for (pos = 120; pos >= 70; pos -= 1) {
servo0.write(pos);
delay(20);
else {
servo0.write(70);
if (distance = 90 || distance <= 90){
else {
delay(5);
kolaha
June 9, 2021, 1:44pm
15
#include <Servo.h>
#define trigPin 12
#define echoPin 11
Servo servo0;
int pos = 70;
int sound = 250;
int i = 0;
int sens;
servo0.attach(9);
servo0.write(pos);
servo0.write(pos);
delay(20);
for (pos = 120; pos >= 70; pos--) {
servo0.write(pos);
delay(20);
else servo0.write(70);
delay(50);
that's doing the same work like my code
kolaha
June 9, 2021, 4:35pm
17
And Serial Port say what?
