#define STEPPER_PIN_1 9
#define STEPPER_PIN_2 10
#define STEPPER_PIN_3 11
#define STEPPER_PIN_4 12
#define Button 0
int step_number = 0; // To keep track of the stepper motor's state
bool motor_direction = true; // Motor direction: true for forward, false for reverse
pinMode(STEPPER_PIN_1, OUTPUT);
pinMode(STEPPER_PIN_2, OUTPUT);
pinMode(STEPPER_PIN_3, OUTPUT);
pinMode(STEPPER_PIN_4, OUTPUT);
pinMode(Button, INPUT); // Set the Button pin as input
// Check if the button is pressed (HIGH means pressed on most buttons)
if (digitalRead(Button) == HIGH) {
motor_direction = !motor_direction; // Reverse direction when button is pressed
delay(500); // Debounce delay to avoid multiple direction changes when button is pressed
// Run the motor in the current direction indefinitely
OneStep(motor_direction);
delay(2); // Small delay to control motor speed
void OneStep(bool dir) {
if (dir) { // If direction is true, move the motor in one direction
switch (step_number) {
case 0:
digitalWrite(STEPPER_PIN_1, HIGH);
digitalWrite(STEPPER_PIN_2, LOW);
digitalWrite(STEPPER_PIN_3, LOW);
digitalWrite(STEPPER_PIN_4, LOW);
case 1:
digitalWrite(STEPPER_PIN_1, LOW);
digitalWrite(STEPPER_PIN_2, HIGH);
case 2:
digitalWrite(STEPPER_PIN_3, HIGH);
case 3:
digitalWrite(STEPPER_PIN_4, HIGH);
} else { // If direction is false, move the motor in the opposite direction
case 0:
case 1:
case 2:
case 3:
// Increment step number and reset if it exceeds 3
step_number++;
if (step_number > 3) {
step_number = 0;
