I am having a difficult time programming what i assumed to be an easy task. I am using a strain gauge with a conditioner that is relaying voltage values to one of the analog inputs on the arduino. That is not the problem though i have the arduino programmed to trigger a relay and blinking LED when the weight limit/ voltage value has been met. I have integrated a button switch that when pressed a single time should cause the LED to stop blinking and remain ON. I am have a hard time getting my program to do this. Right now when the weight limit is reached the LED will blink however i have to hold the button switch down in order for the LED to stop blinking and remain solid. I need the LED to remain solid after a single push so i do not have to hold the button switch down. Any suggestions would be great.
Thanks,
Here is my code:
const int Conditioner = A0; // pin that the conditioner is attached to
const int ledPin = 13; // pin that the arduino LED is attached to
const int external_red = 9; // pin that the external_red LED is attached to
const int relay_1 = 10; // pin that the one channel relay is attached to
const int spec_weight = 125; // an arbitrary value that's in the range of the analog input
const int blue_button_switch = 2; // pin that the blue_button_switch is attached to
int blue_buttonState = 0; // variable for reading the blue_button_switch status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the relay pin as an output:
pinMode(relay_1, OUTPUT);
// initialize the external_red pin as an output:
pinMode(external_red, OUTPUT);
// initialize the blue_button_switch pin as an input:
pinMode(blue_button_switch, INPUT);
// initialize serial communications:
// read the value of the conditioner:
int analogValue = analogRead(Conditioner);
// if the analog value is high enough, turn on the LED and trigger the relay:
if (analogValue >= spec_weight) {
digitalWrite(ledPin, HIGH); // sets the arduino LED on
digitalWrite(relay_1, HIGH); // triggers the channel one relay
}/* else {
digitalWrite(ledPin, LOW);
digitalWrite(relay_1, LOW);
// when the analog value is high enough, cause the external_red led to blink until blue_button_switch is pressed:
while (analogValue >= spec_weight) {
blue_buttonState = digitalRead(blue_button_switch);
// if the blue_button_switch is pressed, cause external_led to turn on:
if (blue_buttonState == LOW){
digitalWrite(external_red, HIGH); // sets the external_red LED on
//if the blue_button_switch is NOT pressed, cause external_led to blink:
else{
delay(500); // waits for a second
digitalWrite(external_red, LOW); // sets the external_red LED off
// print the analog value:
Serial.println(analogValue);
delay(1); // delay in between reads for stability
Go and read the instructions, then go back and modify your post (use the "More --> Modify" option to the bottom right of the post) to mark up the code as such so we can examine it conveniently and accurately.
You happy Paul_B? Haha
However it is good to know so thank you for that.
Thank you for the reply jimbo however i am using a button switch that is not attached to a breadboard it has a ground, signal, and a VCC. Therefor i am unable to wire it the same. As for the code i need it to blink before i press the button and stop blinking when i do. When i have tried similar code it wouldn't blink before i pressed it because it would run into the next command. I was able to make the led turn off and on by a single press but that is not what i want.
Paul__B:
Sounds like a "Keyes" module. You will therefore need to cite the Web link to that module in order for us to be able to advise on how to use it.
I have been unable to find any information on this button switch. It has YW-001 written on it and that is all i know about it.
Look through this, I am sure you can pull out what you need and add it to your sketch:
//Blink without Delay skeleton
//4 examples demonstrated
//LarryD
//LED wiring options
//#define PlusEqualsON //uncomment to invert
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON LOW
#define ledOFF HIGH
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL; //100ms
unsigned long ledOnTime = 5*1000UL; //5 seconds
byte laststartSwitchState = HIGH;
byte buttonState = HIGH;
byte counter = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch = 3; //pushed = LOW
digitalWrite(13,ledOFF);
pinMode(13, OUTPUT);
digitalWrite(12,ledOFF);
pinMode(12, OUTPUT);
digitalWrite(11,ledOFF);
pinMode(11, OUTPUT);
digitalWrite(10,ledOFF);
pinMode(10, OUTPUT);
pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
pinMode(testSwitch, INPUT_PULLUP); //pushed = LOW
} // >>>>>>>>>>>>>> E N D O F s e t u p ( ) <<<<<<<<<<<<<<<<<
//save the current time
currentMillis = millis();
//************************************* E x a m p l e 1
//toggle pin 13 every 200mS
//has 200ms or more gone by?
if (currentMillis - pin13Millis >= 200UL)
//code here runs every 200ms
//get ready for next iteration
pin13Millis = pin13Millis + 200UL;
//toggle pin 13
digitalWrite(13,!digitalRead(13));
//************************************* E x a m p l e 2
//at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
//could be used as a powerup reset signal
if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
//code here runs for 3 seconds after power up, then stops
digitalWrite(12,ledON);
//disable further pin 12 control
flag12 = false;
//************************************* E x a m p l e 3
//if testSwitch is pushed and released
//pin 11 LED goes ON for 5 seconds, then goes OFF
buttonState = digitalRead(testSwitch);
//are we allowed to check the switch and is it pressed?
if(flag11 == true && buttonState == LOW)
//enable timing of LED on pin 11
flag11 = false; //false --> timing is enabled
//turn LED ON
digitalWrite(11,ledON);
//record the time LED turned ON
pin11Millis = currentMillis;
//are we allowed and is it time to control pin 11
if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
//if enabled, code here runs after ledOnTime ms goes by
//allow switch press detection again
flag11 = true; //true --> switch monitoring is enabled
//************************************* E x a m p l e 4
//is it time to check the switches?
//in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
if (currentMillis - SwitchMillis >= debounceMillis)
//code here runs every debounceMillis ms
//get ready for the next iteration
SwitchMillis += debounceMillis;
//go and check the switches
checkSwitches();
//put other non-blocking stuff here
} // >>>>>>>>>>>>>> E N D O F l o o p ( ) <<<<<<<<<<<<<<<<<
// F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
//re-usable for all the switches
boolean thisState;
//************************************* E x a m p l e Push ON push OFF (toggle)
//check if this switch has changed state
thisState = digitalRead(startSwitch);
if (thisState != laststartSwitchState)
//update the switch state
laststartSwitchState = thisState;
//this switch position has changed so do some stuff
//"HIGH condition code"
//switch went from LOW to HIGH
if(thisState == HIGH)
//Do some HIGH switch stuff here
//"LOW condition code"
//switch went from HIGH to LOW
//Do some LOW switch stuff here
digitalWrite(10, !digitalRead(10));
//print number of pushes
counter++;
Serial.println(counter);
} //END of startSwitch code
//similar code for other switches goes here
} //END of checkSwitches()
// E N D O F C O D E
LarryD:
Thank you Larry I was able to achieve what I wanted using some of your example 2.
For anyone else here is the updated code:
boolean flag9 = true; // enable/disable flag
// if the analog value is high enough, turn on the arduino LED and trigger the relay:
}/* else {
// if the blue_button_switch has not been pressed, cause external_led to blink:
if (flag9 == true && blue_buttonState == HIGH){
delay(50); // waits for a second
//if the blue_button_switch is pressed, cause external_led to stop blinking and remain on:
else{
flag9 = false; // disables further pin 9 control
}delay(500);
