Keeping an LED blinking after letting go of a switch
So the other day I posted about getting an Arduino to make an LED turn on with one switch and off with another. I want the LED to blink when I press the first switch and keep blinking until I press the second switch. with the code below, it will blink while i have the first switch pressed, but stop as soon as I let it go. If anyone knows how to extend the blinking until i press down the second switch I would very much appreciate it. Thanks
// constants won't change
const int Switch[] = {7,11};
const int LED =  13;
// variables will change:
int SwitchState = 0;
int ledState = LOW;
unsigned long previousMillis = 0;
const long interval = 100;
  pinMode(LED, OUTPUT);
  // initialize the pushbutton pin as an input:
   for(int x=0; x<=1; x++){
    pinMode(Switch[x], INPUT);
void loop(){
  // read the state of the pushbutton value:
    SwitchState = digitalRead(Switch[x]);
    // check if the pushbutton is pressed.
    // if it is, the buttonState is HIGH:
    if (SwitchState == HIGH && Switch[x] == 7) {
        // turn LED on:
        if (currentMillis - previousMillis >= interval) {
          // save the last time you blinked the LED
          // if the LED is off turn it on and vice-versa:
          if (ledState == LOW) {
            ledState = HIGH;}
            else {
            ledState = LOW;}
    // set the LED with the ledState of the variable:
    digitalWrite(LED, ledState);
    if (SwitchState == HIGH && Switch[x] == 11) {
      // turn LED off:
      digitalWrite(LED, LOW);
When the 1st button is pressed make a Boolean variable true. When the Boolean variable is true, flash a LED. When the 2nd button is pressed make the Boolean variable false.
use the first switch to set a boolean blink to true and use the second switch to set that boolean to false
then test the boolean and if it's true, blink (using the blink without delay method)
in pseudo code it would look like this
if swicth1 is pressed blink = true;
if switch2 is pressed blink = false;
if (blink) {
   if it's time to blink the LED, do it.
Great minds . . .
Yep :)
I got It to work! Thanks people
const int LED =  13;
int ledState = LOW;
boolean BooleanSwitch = LOW;
void loop(){
      BooleanSwitch = HIGH;}
        if (BooleanSwitch == HIGH){
        // turn LED on:
            ledState = HIGH;}
            else {
            ledState = LOW;}
      BooleanSwitch = LOW;}
        if (BooleanSwitch == LOW){
           // turn LED off:
