Hi everyone,
I am trying to control a high current (around 40amp burst, 15amp constant) motor by mosfet chip BTN7971B with tiny85. By the datasheet this chip can handle max 25khz pwm.
Before I control it by atiny85, I tested the chip as following:
pin1: Battery neg-
pin3: 5v by LM1085IS-5.0
pin4: nil
pin5: nil
pin6: nil
pin7: Battery pos+
pin8: power output to motor+
motor - connect to battery neg-
to activate by giving 5v to pin2
The 1st few trigger that worked perfectly but not sure why I burnt 2 of the chips by this setting after few tried (not work anymore, anyway).
I am thinking if pin2 needs pwm signal to handle. Does anyone know what is PRO and CON to use PWM or direct connect the IN pin to 5v? Please advise.
