Controlling led via gsm sim900
hi guys ..
i have arduino uno and gsm sim900 ..
i test it its ok .. send and reseved sms ..
now i want to Controlling led i uploading these code no error but led doesn't turn on ..
whats the problem please ..
#include <SoftwareSerial.h>
char inchar; // Will hold the incoming character from the GSM shield
SoftwareSerial SIM900(2, 3);
int led1 = 10;
int led2 = 11;
int led3 = 12;
int led4 = 13;
  Serial.begin(19200);
  // set up the digital pins to control
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  digitalWrite(led1, HIGH);
  digitalWrite(led2, HIGH);
  digitalWrite(led3, HIGH);
  digitalWrite(led4, HIGH);
  // wake up the GSM shield
  SIM900power();
  SIM900.begin(19200);
  delay(20000);  // give time to log on to network.
  SIM900.print("AT+CMGF=1\r");  // set SMS mode to text
  delay(100);
  SIM900.print("AT+CNMI=2,2,0,0,0\r");
  // blurt out contents of new SMS upon receipt to the GSM shield's serial out
  delay(100);
  Serial.println("Ready...");
void SIM900power()
// software equivalent of pressing the GSM shield "power" button
  digitalWrite(9, HIGH);
  digitalWrite(9, LOW);
  delay(7000);
  //If a character comes in from the cellular module...
  if(SIM900.available() >0)
    inchar=SIM900.read();
    if (inchar=='#')
      delay(10);
      if (inchar=='a')
        delay(10);
        if (inchar=='0')
          digitalWrite(led1, LOW);
        else if (inchar=='1')
        delay(10);
        if (inchar=='b')
          if (inchar=='0')
            digitalWrite(led2, LOW);
          delay(10);
          if (inchar=='c')
            if (inchar=='0')
              digitalWrite(led3, LOW);
            delay(10);
            if (inchar=='d')
              delay(10);
              if (inchar=='0')
                digitalWrite(led4, LOW);
              delay(10);
          SIM900.println("AT+CMGD=1,4"); // delete all SMS
mustafa_abdulwahed7:
// Example 55.7
Is this homework?
hhhhhhhhhhhh ...
can u help me plz :slightly_frowning_face: :slightly_frowning_face:
:frowning: :frowning:
Have you tried simple test code to flash the LEDs? Without the gsm part?
yes i tested it
You went back and edited out the "// Example 55.7". Does that indicate that perhaps you don't want people to know where it came from? http://tronixstuff.com/2014/01/08/tutorial-arduino-and-sim900-gsm-modules/
Would it not have been polite to inform us?
no but u laughed it ..
I do not perfected English in order to discuss why i edit it ..
the example in these url http://tronixstuff.com/2014/01/08/tutorial-arduino-and-sim900-gsm-modules/
Why do you think the same code would work for the author and not for you? That is why I suggested testing the LEDs. How did you test them? Please post your LED test code. Also please post a schematic or photo of your circuit.
    if (inchar=='#')
      delay(10);
If there is data, and the data is a '#', stick your head in the sand for a while. Why?
PaulS:
if (inchar=='#')
      delay(10);
i dont undrestand what you say ...
Why are you calling delay when you KNOW that you got good data?
PaulS:
i got these code on video on youtube .. now i delete all delay in the code but nothing happend
can be problem on SoftwareSerial SIM900(2, 3) ?
Are you getting any data from the SIM900? If so, the that is not the problem.
PaulS:
yes i receved sms from sim900 in library example ..
But you aren't running the library example.
PaulS:
PaulS:
what i do now ? thanks for help im student
what i do now ?
Make liberal use of Serial.print().
PaulS:
can u give me example ?
