Controlling multi stepper motors
Im new to using an Arduino and need some advice.
I want to control 8 stepper motors 28BYJ-48 each motor connected to a motor board driver ULN2003 using an Arduino mega.
Each motor has to run independently of the others at different speeds and times.
Is this possible and how would I connect them.
Any advice appreciated.
Stuart
How do you know what times and speeds? How fast? do they need to go? Do the moves need to be coordinated with each other?
Here's a simulation of coordinated motion with 6 steppers and better drivers than a ULN2003 on an Arduino Mega:
8 steppers need 16 outputs. No problem for a Mega.
About connections... Use the "Search Forum" function up to the right in this window. More then plenty of projects like Yours have been done.
Not with the ULN2003 driver OP has.
Then you need 8 * 4 = 32 outputs.
Leo..
Thanks! Correct but still no problem for a Mega, only for the person fighting the cables....
In a previous 48-motor project I replaced the ULN2003 drivers with TPIC6B595 chips.
Then you only need three pins to rule them all, and you can use a Nano v3.
Wise to get the experience with just one motor, before upscaling to eight.
Leo..
+1 for that.
Works wonders. Maybe even better than the ULN2003 as you don't have that voltage drop of those Darlington transistors.
Thanks for all the replies and info.
Most helpful.
Thanks for your reply to me question re multi stepper motor controls.
Thats very helpful.
When I get more time Im going to study your coding and diagram.
Very kind of you to take the time.
best wishes
Stuart
