Is it possible to controll a rgb Led with one Pin.
I want to use a esp8266 to controll a Button and a rgb Led so I have just one Pin left.
does someone of you knows what i can use for this?
I have a wemos D mini but it is to big for my purpouse so everything you say should by smal.
You could add an I2C expander like the MCP23008 to add 8 input/output pins, but that may be too big. Use 3 pins for outputs for the LEDs and 1 pin as an input for the switch. Other than that I have no suggestions.
Which ESP8266 module do you have? You know that there are many different kinds? What all is connected to the ESP so that you have only 1 pin left? Can you post a schematic of the project so that I know what you are trying to do?
I have i think it is the esp-01 so doesnt it only have to gpio pins to the fist is the switch connected and so i only have one left, with which i want to controll the rgb led.
The MCP23008 could work but I want to make it as smal as possible so an easier solution would be nicer but if it doesn't work i will use the I2C expander
If you read my first post you see that you can use the MCP23008 to control the 3 LEDs and read the switch. So you use the switch pin and the left over pin for the I2C bus, then you will have an almost unlimited number of I/O pins using I2C expanders.
you can use a ALITOVE WS2812B Addressable 5050 smart RGB LED Pixel light, You will need to supply the LED with 5V, ground, and one pin from the ESP.
The #include <Adafruit_NeoPixel.h> library works with the LED. The library has C code written for the ESP.
Example of use
#define PIN 26
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(10, PIN, NEO_GRB + NEO_KHZ800);
pixels.begin(); // This initializes the NeoPixel library.
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
for (int i = 0; i < 2; i++) {
for (int j = 0; j < 2; j++) {
for (int k = 0; k < 2; k++) {
pixels.setPixelColor(0, pixels.Color(i * 255, j * 255, k * 255)); // Moderately bright green color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(200); // Delay for a period of time (in milliseconds).
connected to the Boad are just the switch and until now a blue Led for testing and nothing else so really nothing to complex i can try doing a shematic but if i can use the rx and tx pins it should be fine
