Controlling Servos via Serial monitor
Hi, I'm new to Arduino programming in general. This is my first project with servos.
I am trying to control a servo using the Serial monitor on my computer. The idea is to supply the board with a certain degree (ex 45 degrees) and have the servo move to that position. However, when I input a degree in the monitor, the servo moves to some arbitrarily set position and the serial monitor displays numbers different to what I just input. I don't know whats happening.
#include <Servo.h>
Servo myservo;
int input;
  myservo.attach(9);
  myservo.write(75);
    input = Serial.read();
    myservo.write(input);
    Serial.println(input);
    delay (1000);
Servo test code
// zoomkat 12-25-13 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// Send an a to attach servo or d to detach servo
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
String readString; //String captured from serial port
Servo myservo;  // create servo object to control a servo
int n; //value to write to servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7, 500, 2500);  //the pin for the servo control, and range if desired
  Serial.println("servo all-in-one test code 12-25-13"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
      // attach or detach servo if desired
    if (readString == "d") {
      while (digitalRead(7)) {} //delay loop until pin 7 is low
      myservo.detach(); //detach servo
      Serial.println("servo detached");
      goto bailout; //jump over writing to servo
    if (readString == "a") {
      myservo.attach(7); //reattach servo to pin 7
      Serial.println("servo attached");
      goto bailout;
    n = readString.toInt();  //convert readString into a number
    // auto select appropriate value
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
bailout: //reenter code loop
    Serial.print("Last servo command position: ");
    Serial.println(myservo.read());
    readString=""; //empty for next input
You are reading the serial buffer without checking that anything was actually received or is available to read, also AFAIK the values you are getting via serial are ASCII representations, you will need to actually convert it to an integer. Try something like this..
#include <Servo.h>
Servo myservo;
int input;
  myservo.attach(9);
  myservo.write(75);
  if (Serial.available() > 0) {
    input = Serial.parseInt();
    delay (1000);
Have a look at serial input basics.
...R
