I purchased an Arduino Uno R3, the tilt/pan assembly with micro servos, the motor shield V2.3 and 2 rotary encoders with the aim of being able to control the tilt/pan servos with the encoders.
I've hooked everything up and tested the servos using the swing sketch and they work fine. I haven't tested the encoders because that's kind of where I'm stuck.
I got hold of the code for a rotary encoder volume control here:
I butchered this code to include another encoder and then make the changes move the servos... however my code doesn't seem to work.
When I upload it, the servos move to there central positions and the only thing which happens is if I push an encoder button one servo will go all the way to the 0 or 180 position and keep trying to move past that point till I reset the board.
Here is my butchered code:
#include <Servo.h>
Servo servo1;
Servo servo2;
#define PIN_ENCODER1_A 2
#define PIN_ENCODER2_A 3
#define PIN_ENCODER1_B 4
#define PIN_ENCODER2_B 5
#define PIN_ENCODER1_SWITCH 6
#define PIN_ENCODER2_SWITCH 7
#define TRINKET_PINx PIND //wtf is this...
static uint8_t enc1_prev_pos = 0;
static uint8_t enc1_flags = 0;
static char sw1_was_pressed = 0;
static uint8_t enc2_prev_pos = 0;
static uint8_t enc2_flags = 0;
static char sw2_was_pressed = 0;
int pos1 = 0;
int pos2 = 0;
servo1.attach(10);
servo2.attach(9);
// set pins as input with internal pull-up resistors enabled
pinMode(PIN_ENCODER1_A, INPUT_PULLUP);
pinMode(PIN_ENCODER2_A, INPUT_PULLUP);
pinMode(PIN_ENCODER1_B, INPUT_PULLUP);
pinMode(PIN_ENCODER2_B, INPUT_PULLUP);
pinMode(PIN_ENCODER1_SWITCH, INPUT_PULLUP);
pinMode(PIN_ENCODER2_SWITCH, INPUT_PULLUP);
// get an initial reading on the encoder pins
if (digitalRead(PIN_ENCODER1_A) == LOW) {
enc1_prev_pos |= (1 << 0);
if (digitalRead(PIN_ENCODER1_B) == LOW) {
enc1_prev_pos |= (1 << 1);
if (digitalRead(PIN_ENCODER2_A) == LOW) {
enc2_prev_pos |= (1 << 0);
if (digitalRead(PIN_ENCODER2_B) == LOW) {
enc2_prev_pos |= (1 << 1);
int8_t enc1_action = 0; // 1 or -1 if moved, sign is direction
int8_t enc2_action = 0;
// note: for better performance, the code will use
// direct port access techniques
// http://www.arduino.cc/en/Reference/PortManipulation
uint8_t enc1_cur_pos = 0;
uint8_t enc2_cur_pos = 0;
// read in the encoder state first
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER1_A)) {
enc1_cur_pos |= (1 << 0);
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER1_B)) {
enc1_cur_pos |= (1 << 1);
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER2_A)) {
enc2_cur_pos |= (1 << 0);
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER2_B)) {
enc2_cur_pos |= (1 << 1);
// if any rotation at all
if (enc1_cur_pos != enc1_prev_pos)
if (enc1_prev_pos == 0x00)
// this is the first edge
if (enc1_cur_pos == 0x01) {
enc1_flags |= (1 << 0);
else if (enc1_cur_pos == 0x02) {
enc1_flags |= (1 << 1);
if (enc2_cur_pos != enc2_prev_pos)
if (enc2_prev_pos == 0x00)
if (enc2_cur_pos == 0x01) {
enc2_flags |= (1 << 0);
else if (enc2_cur_pos == 0x02) {
enc2_flags |= (1 << 1);
if (enc1_cur_pos == 0x03)
// this is when the encoder is in the middle of a "step"
enc1_flags |= (1 << 4);
else if (enc1_cur_pos == 0x00)
// this is the final edge
if (enc1_prev_pos == 0x02) {
enc1_flags |= (1 << 2);
else if (enc1_prev_pos == 0x01) {
enc1_flags |= (1 << 3);
if (enc2_cur_pos == 0x03)
enc2_flags |= (1 << 4);
else if (enc2_cur_pos == 0x00)
if (enc2_prev_pos == 0x02) {
enc2_flags |= (1 << 2);
else if (enc2_prev_pos == 0x01) {
enc2_flags |= (1 << 3);
// check the first and last edge
// or maybe one edge is missing, if missing then require the middle state
// this will reject bounces and false movements
if (bit_is_set(enc1_flags, 0) && (bit_is_set(enc1_flags, 2) || bit_is_set(enc1_flags, 4))) {
enc1_action = 1;
else if (bit_is_set(enc1_flags, 2) && (bit_is_set(enc1_flags, 0) || bit_is_set(enc1_flags, 4))) {
enc1_action = 1;
else if (bit_is_set(enc1_flags, 1) && (bit_is_set(enc1_flags, 3) || bit_is_set(enc1_flags, 4))) {
enc1_action = -1;
else if (bit_is_set(enc1_flags, 3) && (bit_is_set(enc1_flags, 1) || bit_is_set(enc1_flags, 4))) {
enc1_action = -1;
if (bit_is_set(enc2_flags, 0) && (bit_is_set(enc2_flags, 2) || bit_is_set(enc2_flags, 4))) {
enc2_action = 1;
else if (bit_is_set(enc2_flags, 2) && (bit_is_set(enc2_flags, 0) || bit_is_set(enc2_flags, 4))) {
enc2_action = 1;
else if (bit_is_set(enc2_flags, 1) && (bit_is_set(enc2_flags, 3) || bit_is_set(enc2_flags, 4))) {
enc2_action = -1;
else if (bit_is_set(enc2_flags, 3) && (bit_is_set(enc2_flags, 1) || bit_is_set(enc2_flags, 4))) {
enc2_action = -1;
enc1_flags = 0; // reset for next time
enc2_flags = 0; // reset for next time
enc1_prev_pos = enc1_cur_pos;
enc2_prev_pos = enc2_cur_pos;
if (enc1_action > 0) {
pos1 += 1;
servo1.write(pos1); // Clockwise
else if (enc1_action < 0) {
pos1 -= 1;
servo1.write(pos1); // Counterclockwise,
if (enc2_action > 0) {
pos2 += 1;
servo1.write(pos2); // Clockwise
else if (enc2_action < 0) {
pos2 -= 1;
servo1.write(pos2); // Counterclockwise
// remember that the switch is active low
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER1_SWITCH))
if (sw1_was_pressed == 0) // only on initial press, so the keystroke is not repeated while the button is held down
pos1=0; // Encoder pushed down, toggle mute or not
servo1.write(pos1);
delay(5); // debounce delay
sw1_was_pressed = 1;
if (sw1_was_pressed != 0) {
if (bit_is_clear(TRINKET_PINx, PIN_ENCODER2_SWITCH))
if (sw2_was_pressed == 0) // only on initial press, so the keystroke is not repeated while the button is held down
pos2=0; // Encoder pushed down, toggle mute or not
servo1.write(pos2);
sw2_was_pressed = 1;
if (sw2_was_pressed != 0) {
I'm very useless at coding so I'm sure there are errors in there, probably in the way I duplicated the nested if and else statements. I don't know how to think about how it could be wrong yet without example so I hope someone can help.
Cheers,
Tim
