I am making use of the code below to control the speed of an AC fan and the intensity of an AC Lamp with an Uno.
The problem I am having is that, when I set the lamp intensity to low or medium, the fan turns on at a very low speed as well, and I cannot turn it off even when setting the fan to off.
Also if I turn the lamp on and then off, the fan (which is still set as off), will spin slowly for a second or two in random intervals.
For troubleshooting purposes, I did separate this program into two programs, controlling each device and its circuit separately, and it works perfectly, but when I combine them, I get the above problem.
Any assistance in troubleshooting or ideas to solve this would be appreciated. Haven't attempted AC control before.
int PWM = 3;
int FAN = 4;
int dimming;
Serial.println("Serial connection started, waiting for instructions…n0 = Offn1 = 25%n2 =50%n3 = 75%n4 = 100%");
pinMode(PWM, OUTPUT);
pinMode(FAN, OUTPUT);
attachInterrupt(0, zero_crosss_int, RISING);
void zero_crosss_int()
// function to be fired at the zero crossing to dim the light
int dimtime = (75 * dimming); // For 60Hz =>65
delayMicroseconds(dimtime); // Off cycle
digitalWrite(FAN, HIGH); // triac firing
delayMicroseconds(10); // triac On propogation delay
//(for 60Hz use 8.33)
digitalWrite(FAN, LOW); // triac Off
void loop ()
if (Serial.available()) {
char ser = Serial.read(); //read serial as a character
switch (ser)
/* Lamp Control */
case '0':
analogWrite(PWM, 0); //lamp Off
case '1':
analogWrite(PWM, 50); //lamp low
case '2':
analogWrite(PWM, 130); //lamp medium
case '3':
analogWrite(PWM, 255); //lamp high
/* Fan Control */
case '4':
dimming = 128; //fan off
case '5':
dimming = 90; //fan low
case '6':
dimming = 65; //fan medium
case '7':
dimming = 35; //fan high
default:
Serial.println("Invalid entry");
The circuits it controls is based on these:
Lamp
Fan
The code and the circuits are based on these posts:
