I’m trying to control two servos through serial to controll a nerf gun, and its gonna be awesome. im gonna put a camera on it and have it go to my ipod touch, and controll it all with OSCemote on my ipod touch. Does anyone have any good code like this, but for two servos instead of one:
- NewSerialServo
- Servo control from the Serial port
- Alteration of the control interface to use < and > keys
- to slew the servo horn left and right. Works best with
- the Linux/Mac terminal “screen” program.
- Created 10 December 2007
- copyleft 2007 Brian D. Wendt
/** Adjust these values for your servo and setup, if necessary **/
int servoPin = 2; // control pin for servo motor
int minPulse = 600; // minimum servo position
int maxPulse = 2400; // maximum servo position
int turnRate = 100; // servo turn rate increment (larger value, faster rate)
int refreshTime = 20; // time (ms) between pulses (50Hz)
/** The Arduino will calculate these values for you **/
int centerServo; // center servo position
int pulseWidth; // servo pulse width
int moveServo; // raw user input
long lastPulse = 0; // recorded time (ms) of the last pulse
pinMode(servoPin, OUTPUT); // Set servo pin as an output pin
centerServo = maxPulse - ((maxPulse - minPulse)/2);
pulseWidth = centerServo; // Give the servo a starting point (or it floats)
Serial.println(" Arduino Serial Servo Control");
Serial.println(“Press < or > to move, spacebar to center”);
// wait for serial input
if (Serial.available() > 0) {
// read the incoming byte:
moveServo = Serial.read();
// ASCII ‘<’ is 44, ASCII ‘>’ is 46 (comma and period, really)
if (moveServo == 44) { pulseWidth = pulseWidth - turnRate; }
if (moveServo == 46) { pulseWidth = pulseWidth + turnRate; }
if (moveServo == 32) { pulseWidth = centerServo; }
// stop servo pulse at min and max
if (pulseWidth > maxPulse) { pulseWidth = maxPulse; }
if (pulseWidth < minPulse) { pulseWidth = minPulse; }
// print pulseWidth back to the Serial Monitor (uncomment to debug)
// Serial.print("Pulse Width: ");
// Serial.print(pulseWidth);
// Serial.println(“us”); // microseconds
// pulse the servo every 20 ms (refreshTime) with current pulseWidth
// this will hold the servo’s position if unchanged, or move it if changed
if (millis() - lastPulse >= refreshTime) {
digitalWrite(servoPin, HIGH); // start the pulse
delayMicroseconds(pulseWidth); // pulse width
digitalWrite(servoPin, LOW); // stop the pulse
lastPulse = millis(); // save the time of the last pulse
