Servo Control through serial monitor
hello guys!
I am working on controlling 2 servos from the serial monitor thorugh commands like these:
PP ----> returns the pan position
PP1500 ----> moves the servo to position 1500
I posted my code below
#include <Servo.h>
char buffer[16];
int  bufferIndex = 0;
Servo myServo1;
Servo myServo2;
  pinMode(9, OUTPUT);
  pinMode(8, OUTPUT);
  myServo1.attach(9);
  myServo2.attach(8);
  Serial.println("Welcome!");
    static int val = 0;
    static int temp = 150;
    if( Serial.available())
       char ch = Serial.read();
           if( ch == '\r')  // is this the terminating carriage return
              bufferIndex = 0;
              if (strcmp (buffer,"a") == 0) {
                Serial.println("waiting for 1 second");
              if (strcmp (buffer,"pp") == 0) {
                if (Serial.available())
                  char temp = Serial.read();
                  switch (temp)
                    case '0'...'9':
                      val = val * 10 + ch - '0';
                    case 'p':
                      myServo1.write(val);
                      Serial.print("horizontal servo is set to: ");
                      Serial.print(val, DEC);
                      Serial.println(" degrees");
                      val = 0;
                  Serial.print("current pan position is ");
                  Serial.println(val, DEC);
              if (strcmp (buffer,"tp") == 0) {
                Serial.print("current tilt position is ");
              if (strcmp (buffer," ") == 0) {
                val = 90;
                myServo2.write(val);
                Serial.println("both servos are reset");
                val = 0;
              for (int i=0; i<=20; i++)
                buffer[i] = '\0';
             buffer[ bufferIndex++ ] = ch; // add the character into the buffer
the first part works fine which is returning the pan position, but the second part where you tell the servo to move does not seem to work.
please help me and guide me to where i should make modifications in the code considering that i am new to Arduino.
thanks in advance.
                  switch (temp)
                    case '0'...'9':
After the pp, you read a single character. Hard to stuff "1500" into a single character, isn't it. Perhaps the use of a loop to read data up to the end of packet marker is needed. You are sending some kind of end-of-packet marker, aren't you?
but what about if there was no end-of-packet marker?!
the command is supposed to look like this:
PP1500
How do you know when to stop reading There is a reason that we use punctuation symbols when typing It makes it much easier to know when a sentence ends, doesn't it
so i found some code from another thread and modified it to work with my servos:
  while (Serial.available()) {
    delay(10);
    if (Serial.available() >0) {
	char c = Serial.read();  //gets one byte from serial buffer
	readString += c; //makes the string readString
  if (readString.length() >0) {
	// expect a string like 07002100 containing the two servo positions
	command = readString.substring(0, 2);
        servo1 = readString.substring(2, 6); //get the first four characters
	servo2 = readString.substring(2, 6); //get the next four characters
	int n1; //declare as number
	int n2;
        if (command == "pp")
      	  if (servo1 == "")
            char carray1[6]; //magic needed to convert string to a number
      	    servo1.toCharArray(carray1, sizeof(carray1));
      	    n1 = atoi(carray1);
            myservo1.writeMicroseconds(n1); //set servo position
so now when i enter something like this in the terminal
PP2000
the servo moves accordingly, but when i enter the command to get the current position
PP
the code assumes that i entered
PP0000
and moves the servo to the initial position which is zero
how can i modify so that it can stop after the second character?
Gee, I don't know. You might consider using an end-of-packet marker. Or not.
Some code for two servos. If you are using the serial monitor, you don't need an end of packet marker as the code is processed much faster than you can type characters and hit the enter key. :wink:
// zoomkat 11-22-10 serial servo (2) test
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
// two servo setup with two servo commands
// send eight character string like 15001500 or 14501550
#include <Servo.h>
String readString, servo1, servo2;
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
  myservo1.attach(6);  //the pin for the servo control
  myservo2.attach(7);
  Serial.println("servo-test-21"); // so I can keep track of what is loaded
    delay(1);
      Serial.println(readString); //see what was received
      servo1 = readString.substring(0, 4); //get the first four characters
      servo2 = readString.substring(4, 8); //get the next four characters
      Serial.println(servo1);  //print to serial monitor to see results
      Serial.println(servo2);
      int n2;
      n1 = atoi(carray1);
      char carray2[6];
      servo2.toCharArray(carray2, sizeof(carray2));
      n2 = atoi(carray2);
      myservo2.writeMicroseconds(n2);
    readString="";
No data is sent until you hit the enter key. Then, it is all sent, one character at a time.
The Arduino CAN read data faster than it can be sent. Much faster.
Of course, if you are willing to take a break after each character, and do nothing for a while, you can make the Arduino run slower than serial data can be sent.
If this is a problem, use an end of packet marker.
But it isn't using the serial monitor. :wink:
What isn't?
What isn't?
Your imiginary issue with not having an end of packet marker when sending packets using the serial monitor. Perhaps you were speaking to some other issue?
hi zoomkat! thanx for your input.
here is my code so far:
#include <Servo.h>
int lastReadPan = 1500;
int lastReadTilt = 1500;
String readString, servo1, servo2, command, command2;
Servo myservo2;
  myservo1.attach(9);  //the pin for the servo control
  myservo2.attach(8);
  Serial.println("welcome!"); // so I can keep track of what is loaded
    delay(10);
  if (readString.length() > 0) {
	//Serial.println(readString); //see what was received
	//expect a string like 07002100 containing the two servo positions
	command2 = readString.substring(0, 1);
	//Serial.println(servo1);  //print ot serial monitor to see results
	//Serial.println(servo2);
	int n2;
        if (command2 == "a")
        if (command2 == " ")
          myservo1.writeMicroseconds(1500);
          myservo2.writeMicroseconds(1500);
          lastReadPan = 1500;
          if (servo1 == '\r')
            Serial.println(lastReadPan, DEC);
    	    n1 = atoi(carray1);
            lastReadPan = n1;
        if (command == "tp")
          if (servo2 == '\r')
            Serial.println(lastReadTilt, DEC);
            char carray2[6]; //magic needed to convert string to a number
    	    n2 = atoi(carray2);
            myservo2.writeMicroseconds(n2); //set servo position
            lastReadTilt = n2;
        readString="";
now i can run commands like
PP2500 ----------> the servo moves accordingly
PP ----------> returns the current pan position
what i want to do now is modify the code so that it reads:
PP-2500
notice the minus sign which should mean turn to the left
how can i make the code look for the minus sign and if it does not find the minus sign it will assume "turn right"?
thanks
ok nevermind i figured it out
here is my latest code
#include <Servo.h>
int lastReadPan = 90;
int lastReadTilt = 90;
int p, p2, t, t2;
String readString, servo1, servo11, servo2, servo22, command, command2, sign;
Servo myservo2;
//  myservo11.attach(9);
  myservo2.attach(8);
    delay(10);
        sign = readString.substring(2, 3);
        servo1 = readString.substring(2, 5);
        servo11 = readString.substring(3, 6);
        servo22 = readString.substring(3, 6); //get the first four characters
	servo2 = readString.substring(2, 5); //get the next four characters
	int n2;
          myservo1.write(90);
          myservo2.write(90);
          lastReadPan = 90;
          lastReadTilt = 90;
          if (servo1 == '\r')
            if (sign == "-")
              char carray11[6]; //magic needed to convert string to a number
    	      servo11.toCharArray(carray11, sizeof(carray11));
    	      n1 = atoi(carray11);
              if (n1 <= 90)
                p2 = 90 - n1;
                p = map(p2,0,90,90,180);
                myservo1.write(p); //set servo position
                lastReadPan = -n1;
                //Serial.println("minus");
                Serial.println("invalid input!");
    	      n1 = atoi(carray1);
              if (n1 <= 90)
                myservo1.write(n1); //set servo position
                lastReadPan = n1;
          if (servo2 == '\r')
            if (sign == "-")
              char carray22[6]; //magic needed to convert string to a number
    	      servo22.toCharArray(carray22, sizeof(carray22));
    	      n2 = atoi(carray22);
              if (n2 <= 90)
                t2 = 90 - n2;
                t = map(t2,0,90,90,180);
                myservo2.write(t); //set servo position
                lastReadTilt = -n2;
    	      n2 = atoi(carray2);
              if (n2 <= 90)
                myservo2.write(n2); //set servo position
                lastReadTilt = n2;
        readString="";
the code works fine with both a minus sign or not and executes accordingly
now my goal is to provide a continuous serial input to test the two servos , i.e., something like this:
pp45 --------------> move right to position 45
a --------------> wait for 1 second
pp-80 --------------> move left to position 80
a
tp-60 --------------> move down to position -60
a
tp20 --------------> move up to position 20
i don't want to enter the commands manually so please help me on how to provide something like this to the arduino terminal?
thanks
Well, if you don't want to type you probably need to make a program or setup to provide you some type of GUI to send the control commands. Below is an example of a wed based GUI to control servos.
http://web.comporium.net/~shb/wc2000-PT-script.htm
thanks for the link
but i am not entirely sure how to use it, could you explain more?
The web page contains clickable links (which forms the GUI with which the user interacts), that when clicked send a get request to a web server (apache in this case, or could be an arduino with an ethernet shield). The web server takes info from the get request and performs the action to control the servo. In the apache server setup, a batch file is executed which sends the servo control info out the pc serial port to a servo controller. With an ethernet shield, the arduino runs the web server program that takes the servo control info from the get request and positions the servo accordingly.
I am having the same problem you mentioned earlier, my program works only for the first time, after that it just twitches. :slight_smile:
vivanta:
Post your code and a diagram of how the servo is wired.
Don't power the servo from the Arduino 5v pin - give it a separate power supply and connect the servo GND to the Arduino GND.
...R
Hi hussam
I tried to compile your code but got the following errors. What could be wrong?
Arduino: 1.5.7 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Build options changed, rebuilding all
servoMotorControl_2_r1.ino: In function 'void loop()':
servoMotorControl_2_r1.ino:75:25: error: invalid conversion from 'char' to 'const char*' [-fpermissive]
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:220:0,
from servoMotorControl_2_r1.ino:10:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WString.h:143:16: error: initializing argument 1 of 'unsigned char String::operator==(const char*) const' [-fpermissive]
unsigned char operator == (const char cstr) const {return equals(cstr);}
servoMotorControl_2_r1.ino:126:25: error: invalid conversion from 'char' to 'const char
' [-fpermissive]
unsigned char operator == (const char *cstr) const {return equals(cstr);}
enabled in File > Preferences.
hussam:
#include <Servo.h>
int p, p2, t, t2;
Servo myservo2;
  myservo2.attach(8);
    delay(10);
int n2;
          myservo1.write(90);
          myservo2.write(90);
          lastReadPan = 90;
          lastReadTilt = 90;
          if (servo1 == '\r')
            if (sign == "-")
              if (n1 <= 90)
                p2 = 90 - n1;
                lastReadPan = -n1;
          n1 = atoi(carray1);
              if (n1 <= 90)
                lastReadPan = n1;
          if (servo2 == '\r')
            if (sign == "-")
              if (n2 <= 90)
                t2 = 90 - n2;
                lastReadTilt = -n2;
          n2 = atoi(carray2);
              if (n2 <= 90)
                lastReadTilt = n2;
        readString="";
a
a
thanks
Just commentary
I have found reading both Servo files ( header and source) to explain few things about “standard” servos.
The main one being – the Servo accepts two numerical info – the “degree” range 0 thru 180 refers to true angle position / degrees of servo, the range above 500 (something ) refers to microseconds time to set the servo to desired position / angle. This timing data should be in servo data sheet.
The servo should “assume idle position” on power up, but so far I have not found many references to this, but I have not look that hard. (It would be prudent to set it to 0 or whatever desired position initially anyway.)
Since the expected “degrees” range is from 0 to 180 only positive numbers should are used.
I have not look if Servo class methods checks for this range validity, only above 500 it switches to microseconds.
Same goes for “microseconds” range , how do you set negative time?
I really thing servo (hardware) data sheet should tell which data to send – true degrees or microseconds.
It looks as in your case microseconds are used to set the servo position.
Lastly, SOME servos setting speed can be controlled by using faster refresh rate / frequency.
Arduino Servo class is “hardwired” / set to use 50Hz refresh frequency only.
