Controllo rotazione albero motore stepper con un encoder
Salve, ho bisogno del vostro aiuto per correggere il seguente codice utile a controllare la rotazione dell'albero di un motore passo passo mediante la rotazione della manopola di un encoder ottico.
di seguito il codice:
#include "Stepper.h"
#define STEPS 32   // Number of steps for one revolution of Internal shaft
                   // 2048 steps for one revolution of External shaft
volatile boolean TurnDetected; // need volatile for Interrupts
volatile boolean rotationdirection; // CW or CCW rotation
const int PinCLK=2;    // Generating interrupts using CLK signal - CANALE A del mio encoder
const int PinDT=3;     // Reading DT signal - CANALE B del mio encoder
const int PinSW=4;     // Reading Push Button switch - COSA FACCIO CON QUESTO?
int RotaryPosition=0;     //To store Stepper Motor Position
int PrevPosition;      //Previous Rotary position Value to chech accuracy
int StepsToTake;      // How much to move Stepper
// Setup of proper sequencing for Motor Driver Pins
// In1, In2, In3, In4 in the sequence 1-3-2-4
Stepper small_stepper(STEPS, 8, 10, 9, 11);
//Interrupt routine runs if CLK goes from HIGH to LOW
void isr () {
  delay(4); // delay for Debouncing
  if (digitalRead(PinCLK))
     rotationdirection= digitalRead(PinDT);
    rotationdirection= !digitalRead(PinDT);
  TurnDetected = true;
void setup () {
pinMode(PinCLK, INPUT);
pinMode(PinDT, INPUT);
pinMode(PinSW, INPUT);
digitalWrite(PinSW, HIGH); // Pull-Up resistor for switch
attachInterrupt (0, isr, FALLING); // interrupt 0 always connected to pin 2 on Arduino UNO
void loop () {
  small_stepper.setSpeed(700); //Max seems to be 700
  if (!(digitalRead(PinSW))) {    // check if button is pressed
      if (RotaryPosition == 0) {  // check if button was already pressed
        small_stepper.step(-(RotaryPosition*50));
        RotaryPosition=0;   // Reset position to ZERO
  // Runs if rotation was detected
  if (TurnDetected) {
    PrevPosition = RotaryPosition; // Save previous position in variable
    if (rotationdirection){
      RotaryPosition=RotaryPosition-1; } // decrase Position by 1
    else {
      RotaryPosition=RotaryPosition+1; }  // increase Position by 1
    TurnDetected = false;   // do NOT repeat IF loop until new rotation dected
    // Which direction to move Stepper motor
    if ((PrevPosition + 1) == RotaryPosition) { // Move motor CW
      StepsToTake=50;
      small_stepper.step(StepsToTake);
    if ((RotaryPosition + 1) == PrevPosition)  {
      StepsToTake= -50;
      digitalWrite(8, LOW);
      digitalWrite(9, LOW);
      digitalWrite(10, LOW);
      digitalWrite(11, LOW);
Tale sketch è stato ideato per il seguente encoder:
Io vorrei invece utilizzare un encoder ottico Bourns ENA1J-B28 L00128L (scheda tecnica in allegato) - con un motore passo passo bipolare 0.9°, 5.63 V, 0.67 A (scheda tecnica allegata) utilizzando un driver A4988.
(schema elettrico generale allegato).
In sostanza i pin CLK e DT dell'encoder rotativo dovrebbero corrispondere ai pin A e B del mio encoder, SW che rappresenta il pulsante interno, non lo collego perché il mio encoder ne è sprovvisto e quindi come potrei gestire le righe di programma dedicate a questo pulsante?
Lo sketch riesco a caricarlo completamente, ma non si muove nulla purtroppo.
Quale potrebbe essere il problema?
Vi ringrazio in anticipo e vi saluto
Encoder rotativo - scheda tecnica.pdf (392 KB)
Motore passo passo - scheda tecnica.pdf (64.9 KB)
schema elettrico.pdf (61.1 KB)
Una domanda... sulla base di cosa hai disegnato lo schema elettrico?
Perché, encoder a parte, la libreria usata nello sketch che hai messo è inizializzata con tutt'altri pin, ma soprattutto non funziona con il tuo tipo di driver che vuole una coppia di segnali step/dir.
