Conversion from 'unsigned char' to 'arduino::string' is ambiguous
I am trying to compile my sketch and I am caught in an loop with the following error:
conversion from 'unsigned char' to 'arduino::string' is ambiguous
Can you help me please as my attempts to fix it has brought me back to where I started
#include <ArduinoBLE.h>
// Motor control pins
const int ENA = 5;
const int IN1 = 6;
const int IN2 = 7;
BLEService motorService("19B10000-E8F2-537E-4F6C-D104768A1214"); // Define the motor control service
BLEByteCharacteristic motorControlCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite); // Define the motor control characteristic
int speed = 0; // Motor speed
  // Configure motor control pins
  pinMode(ENA, OUTPUT);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  // Initialize BLE
  if (!BLE.begin()) {
    Serial.println("Starting BLE failed!");
    while (1);
  // Set advertised local name and service UUID
  BLE.setLocalName("ModelRailway");
  BLE.setAdvertisedService(motorService);
  // Add characteristics to the service
  motorService.addCharacteristic(motorControlCharacteristic);
  // Add service
  BLE.addService(motorService);
  // Start advertising
  BLE.advertise();
  Serial.println("BLE Motor control peripheral");
  // Listen for BLE connections
  BLEDevice central = BLE.central();
  // If a central is connected to peripheral
  if (central) {
    Serial.print("Connected to central: ");
    Serial.println(central.address());
    // While the central is still connected
    while (central.connected()) {
      // Check if characteristic value is available
      if (motorControlCharacteristic.written()) {
        // Allocate a byte array to store the characteristic value
        byte data[1];
        // Read the characteristic value (up to 1 byte) - Corrected argument
        if (motorControlCharacteristic.read(data, sizeof(data))) {
          // Process the received data (assuming 1 byte)
          unsigned char cmd = data[0];
          // Process the command based on the character
          if (cmd == 'F') {
            forward();
          } else if (cmd == 'B') {
            backward();
          } else if (cmd == 'S') {
            stop();
          } else if (cmd >= '0' && cmd <= '9') { // Check for digits (0-9)
            speed = map(cmd - '0', 0, 10, 0, 255); // Corrected mapping for digits
            analogWrite(ENA, speed);
          Serial.println("Failed to read characteristic value");
    // When the central disconnects, print it out.
    Serial.print(F("Disconnected from central: "));
void forward() {
  digitalWrite(IN1, HIGH);
  digitalWrite(IN2, LOW);
void backward() {
  digitalWrite(IN1, LOW);
  digitalWrite(IN2, HIGH);
void stop() {
Post the complete text of the error message. There is information in the message yhat is lost if you paraphrase. Use the "Copy error message" buyton.
Sorry, here is the error
Arduino: 1.8.13 (Linux), Board: "Arduino NANO 33 IoT"
/home/pi/Arduino/sketch_apr18a/sketch_apr18a.ino: In function 'void loop()':
sketch_apr18a:57:59: error: conversion from 'unsigned char' to 'arduino::String' is ambiguous
         String command = motorControlCharacteristic.value();
In file included from /home/pi/.arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/IPAddress.h:24:0,
                 from /home/pi/.arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/ArduinoAPI.h:30,
                 from /home/pi/.arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/Arduino.h:23,
                 from sketch/sketch_apr18a.ino.cpp:1:
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/String.h:74:2: note: candidate: arduino::String::String(const arduino::__FlashStringHelper*) <near match>
  String(const __FlashStringHelper *str);
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/String.h:74:2: note:   conversion of argument 1 would be ill-formed:
sketch_apr18a:57:58: error: invalid conversion from 'unsigned char' to 'const arduino::__FlashStringHelper*' [-fpermissive]
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/String.h:70:2: note: candidate: arduino::String::String(const char*) <near match>
  String(const char *cstr = "");
/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/String.h:70:2: note:   conversion of argument 1 would be ill-formed:
sketch_apr18a:57:58: error: invalid conversion from 'unsigned char' to 'const char*' [-fpermissive]
sketch_apr18a:65:13: error: 'forward' was not declared in this scope
             forward();
/home/pi/Arduino/sketch_apr18a/sketch_apr18a.ino:65:13: note: suggested alternative: 'fread'
             forward();
             fread
sketch_apr18a:67:13: error: 'backward' was not declared in this scope
             backward();
sketch_apr18a:69:13: error: 'stop' was not declared in this scope
             stop();
/home/pi/Arduino/sketch_apr18a/sketch_apr18a.ino:69:13: note: suggested alternative: 'ltoa'
             stop();
             ltoa
exit status 1
option enabled in File -> Preferences.
The error does not match the code you posted in the first message.
The error points to the line
There is no such line in your code.
Please show your actual code.
i don't see where there is a read() with arguments. this compiles but there appear to be other problems
                byte cmd = motorControlCharacteristic.read();
                if (cmd) {
