Hi - Having some trouble converting this code from an Arduino Uno R3 to an R4. It manipulates the USART Control and Status Register B to set for 9-bit operation (changes the parity bit). Looking for the equivalent calls that are compatible with the R4:
A much more sensible approach would be to learn how to receive 9 bit serial data on the relevant R4 processor, since it and its peripherals have essentially no relationship to those of the Uno R3.
If you're just looking to send/receive 8 bits with parity, you might want to try out Serial1.begin(baud, SERIAL_8E1); or Serial1.begin(baud, SERIAL_8O1);
The protocol of the device I am communicating with expects the 9th parity bit to be set to 1 (mark parity) when sending the data and then set to 0 (space parity) when done; example from c#:
Byte[] GenPoll = { 0x80, 0x81 };
SerialPort1.Parity = Parity.Mark;
SerialPort1.Write(GenPoll, 0, 1); // sends 0x80 gen pol to all machines they wake up and listen for their address OR'ed with 0x80
Thread.Sleep(20); gives the machine time to clear responses from its buffer (prevents duplicate responses)
SerialPort1.Write(GenPoll, 1, 1); // sends out poll to mahne with address of 1
SerialPort1.Parity = Parity.Space;
I have been digging through the R4 code - hardwareserial, serial, serialUSB and it does not seem like it supports mark or space parity as written. Nor do I see any UART registers I can manipulate like on the R3.
When you say 'Set it for 9-bit'; I am not sure how to do that. The hardwareserial library does not support 9bit mode. So if I do a Serial1.begin(19200,SERIAL_9N1) it fails; if I attempt to update hardwareserial with a definition for SERIAL_9N1 the R4 crashes when trying to execute that line.
I've looked over the docs but I'm not very familiar with low-level manipulation of these registers. Any sample code you could share?
Hello, any news regarding this ?
I also would like to have 9-bit support on UNO R4 !!
Today I can only use 8bit data. Such as "Serial1.begin(9600,SERIAL_8N1)".
N/E/O works fine , but when setting for 7-bit in Serial.begin it compiles but nothing is transmitted. When trying with9-bit. I get a compilation error ...not declared in this scope.
I really think when starting with a new UNO R4, you should be able to use 5-9 bit data.
Today I use Teensy 4.0 where all this works fine (after a small edit in "hardwareSerial.h".
9bit support is a much bigger project than just adding the various smaller configuration combination working. Unless you have a working 9bit Serial class for AVR or some other chip, it means re-writing significant portions of the HardwareSerial class (and introducing incompatibilities with Stream (non-UART Serial-like interfaces.))
So I am creeping closer to my answer; I have a conceptual example of what I need; but I am missing the correct includes from the Renesas SSP for the RA4M1. I downloaded what I think is the SSP from their site but can't find the right set of files to include. Can anyone help me move this further?
Example code:
#include "r_sci_uart.h"
/* UART control structure */
static sci_uart_instance_ctrl_t g_uart_ctrl;
hardware_init();
setNinthBit(); // Set the 9th bit
R_SCI_UART_Write(&g_uart_ctrl, &byte, 1);
resetNinthBit(); // Reset the 9th bit
delay(20);
setNinthBit(); // Set the 9th bit again if needed
void hardware_init(void) {
/* Initialize hardware here, including UART configuration for RA4M1 */
/* Initialize UART control structure */
R_SCI_UART_Open(&g_uart_ctrl, &g_uart_cfg);
void setNinthBit() {
/* Set the 9th bit (T8) for SCI communication on RA4M1 */
g_uart_ctrl.p_reg->SCMR |= SCI_SCIF_SCMR_T8;
void resetNinthBit() {
/* Reset the 9th bit (T8) for SCI communication on RA4M1 */
g_uart_ctrl.p_reg->SCMR &= ~SCI_SCIF_SCMR_T8;
Getting a variety of compile errors like: Compilation error: 'g_uart_cfg' was not declared in this scope.
I have 9-bit tx working on the new Uno r4 wifi and Minima. It takes a couple of tiny tweaks to the core. The core and the boards already support it; we just need to allow access to it by adding a few definitions and a case. I have submitted my code updates as pull requests to the API and Core repos. I am also working on a forum post that outlines the changes needed and how to use them. It is amazing to have true 9-bit functions.
