Hi guys ,
Quisera convert a hexadecimal comes in ASCII , ie block in the series sees aparerecer monitor the hexadecimal code , displayed a name.
I'm trying to find the way but do not know if there is any function that realize such instruction.
Hi guys ,
Probably best to show us what you have so far, then we can propose the best approach based on the context / where the data exists.
e.g. If its in a char[] array, then break each byte apart to high and low nybbles - then ASCIIize it...!
My question is to use RFID-RC522 library on read / write.
What I do is not clear to understand a part of the library is the following:
The problem I have is that a program can not create arduino
where the input variable is in hexadecimal form
and this output in character (ie display a character by the monitor)
Example:
Input -> 63 72 69 73 74 69 61 20 72 6e 6f 6f 6f 6e 61 64 0d 0a 6c
output (serial port) -> cristiano ronaldo
Appears on the screen: cristiano ronaldo
You can help me with some instruction, or you know do this conversion ??
Do you get ASCII codes (hex 63, 72 ...) or characters '6', '3', ' ', '7', '2' ...?
Take the input number and do a Serial.write to output it, not a Serial.print.
Thanks, I solved with Serial.Wirte .
