Convert 9DOF to 0-360° angle
Hi, i'm using a LSM9DS1 sensor via I2C, using the Sparkfun library: link to library
I would like to have an an output a value [0-360] with 0° could be reference of North.
  LSM9DS1_Basic_I2C.ino
  SFE_LSM9DS1 Library Simple Example Code - I2C Interface
  Jim Lindblom @ SparkFun Electronics
  Original Creation Date: April 30, 2015
  https://github.com/sparkfun/LSM9DS1_Breakout
  The LSM9DS1 is a versatile 9DOF sensor. It has a built-in
  accelerometer, gyroscope, and magnetometer. Very cool! Plus it
  functions over either SPI or I2C.
  This Arduino sketch is a demo of the simple side of the
  SFE_LSM9DS1 library. It'll demo the following:
  How to create a LSM9DS1 object, using a constructor (global
  variables section).
  How to use the begin() function of the LSM9DS1 class.
  How to read the gyroscope, accelerometer, and magnetometer
  using the readGryo(), readAccel(), readMag() functions and
  the gx, gy, gz, ax, ay, az, mx, my, and mz variables.
  How to calculate actual acceleration, rotation speed,
  magnetic field strength using the calcAccel(), calcGyro()
  and calcMag() functions.
  How to use the data from the LSM9DS1 to calculate
  orientation and heading.
  Hardware setup: This library supports communicating with the
  LSM9DS1 over either I2C or SPI. This example demonstrates how
  to use I2C. The pin-out is as follows:
	LSM9DS1 --------- Arduino
	 SCL ---------- SCL (A5 on older 'Duinos')
	 SDA ---------- SDA (A4 on older 'Duinos')
	 VDD ------------- 3.3V
	 GND ------------- GND
  (CSG, CSXM, SDOG, and SDOXM should all be pulled high.
  Jumpers on the breakout board will do this for you.)
  The LSM9DS1 has a maximum voltage of 3.6V. Make sure you power it
  off the 3.3V rail! I2C pins are open-drain, so you'll be
  (mostly) safe connecting the LSM9DS1's SCL and SDA pins
  directly to the Arduino.
  Development environment specifics:
	IDE: Arduino 1.6.3
	Hardware Platform: SparkFun Redboard
	LSM9DS1 Breakout Version: 1.0
  This code is beerware. If you see me (or any other SparkFun
  employee) at the local, and you've found our code helpful,
  please buy us a round!
  Distributed as-is; no warranty is given.
// The SFE_LSM9DS1 library requires both Wire and SPI be
// included BEFORE including the 9DS1 library.
#include <Wire.h>
#include <SPI.h>
#include <SparkFunLSM9DS1.h>
// LSM9DS1 Library Init //
// Use the LSM9DS1 class to create an object. [imu] can be
// named anything, we'll refer to that throught the sketch.
LSM9DS1 imu;
// Example I2C Setup //
// SDO_XM and SDO_G are both pulled high, so our addresses are:
// #define LSM9DS1_M	0x1E // Would be 0x1C if SDO_M is LOW
// #define LSM9DS1_AG	0x6B // Would be 0x6A if SDO_AG is LOW
// Sketch Output Settings //
#define PRINT_CALCULATED
//#define PRINT_RAW
#define PRINT_SPEED 250 // 250 ms between prints
static unsigned long lastPrint = 0; // Keep track of print time
// Earth's magnetic field varies by location. Add or subtract
// a declination to get a more accurate heading. Calculate
// your's here:
// http://www.ngdc.noaa.gov/geomag-web/#declination
#define DECLINATION -8.58 // Declination (degrees) in Boulder, CO.
//Function definitions
void printGyro();
void printAccel();
void printMag();
void printAttitude(float ax, float ay, float az, float mx, float my, float mz);
  Wire.begin();
  if (imu.begin() == false) // with no arguments, this uses default addresses (AG:0x6B, M:0x1E) and i2c port (Wire).
    Serial.println("Failed to communicate with LSM9DS1.");
    Serial.println("Double-check wiring.");
    Serial.println("Default settings in this sketch will " \
                   "work for an out of the box LSM9DS1 " \
                   "Breakout, but may need to be modified " \
                   "if the board jumpers are.");
    while (1);
  // Update the sensor values whenever new data is available
  if ( imu.gyroAvailable() )
    // To read from the gyroscope,  first call the
    // readGyro() function. When it exits, it'll update the
    // gx, gy, and gz variables with the most current data.
    imu.readGyro();
  if ( imu.accelAvailable() )
    // To read from the accelerometer, first call the
    // readAccel() function. When it exits, it'll update the
    // ax, ay, and az variables with the most current data.
    imu.readAccel();
  if ( imu.magAvailable() )
    // To read from the magnetometer, first call the
    // readMag() function. When it exits, it'll update the
    // mx, my, and mz variables with the most current data.
    imu.readMag();
  if ((lastPrint + PRINT_SPEED) < millis())
    printGyro();  // Print "G: gx, gy, gz"
    printAccel(); // Print "A: ax, ay, az"
    printMag();   // Print "M: mx, my, mz"
    // Print the heading and orientation for fun!
    // Call print attitude. The LSM9DS1's mag x and y
    // axes are opposite to the accelerometer, so my, mx are
    // substituted for each other.
    printAttitude(imu.ax, imu.ay, imu.az,
                  -imu.my, -imu.mx, imu.mz);
    lastPrint = millis(); // Update lastPrint time
void printGyro()
  // Now we can use the gx, gy, and gz variables as we please.
  // Either print them as raw ADC values, or calculated in DPS.
  Serial.print("G: ");
#ifdef PRINT_CALCULATED
  // If you want to print calculated values, you can use the
  // calcGyro helper function to convert a raw ADC value to
  // DPS. Give the function the value that you want to convert.
  Serial.print(imu.calcGyro(imu.gx), 2);
  Serial.print(", ");
  Serial.print(imu.calcGyro(imu.gy), 2);
  Serial.print(", ");
  Serial.print(imu.calcGyro(imu.gz), 2);
  Serial.println(" deg/s");
#elif defined PRINT_RAW
  Serial.print(imu.gx);
  Serial.print(", ");
  Serial.print(imu.gy);
  Serial.print(", ");
  Serial.println(imu.gz);
#endif
void printAccel()
  // Now we can use the ax, ay, and az variables as we please.
  // Either print them as raw ADC values, or calculated in g's.
  Serial.print("A: ");
  // calcAccel helper function to convert a raw ADC value to
  // g's. Give the function the value that you want to convert.
  Serial.print(imu.calcAccel(imu.ax), 2);
  Serial.print(", ");
  Serial.print(imu.calcAccel(imu.ay), 2);
  Serial.print(", ");
  Serial.print(imu.calcAccel(imu.az), 2);
  Serial.println(" g");
  Serial.print(imu.ax);
  Serial.print(", ");
  Serial.print(imu.ay);
  Serial.print(", ");
  Serial.println(imu.az);
#endif
void printMag()
  // Now we can use the mx, my, and mz variables as we please.
  // Either print them as raw ADC values, or calculated in Gauss.
  Serial.print("M: ");
  // calcMag helper function to convert a raw ADC value to
  // Gauss. Give the function the value that you want to convert.
  Serial.print(imu.calcMag(imu.mx), 2);
  Serial.print(", ");
  Serial.print(imu.calcMag(imu.my), 2);
  Serial.print(", ");
  Serial.print(imu.calcMag(imu.mz), 2);
  Serial.println(" gauss");
  Serial.print(imu.mx);
  Serial.print(", ");
  Serial.print(imu.my);
  Serial.print(", ");
  Serial.println(imu.mz);
#endif
// Calculate pitch, roll, and heading.
// Pitch/roll calculations take from this app note:
// https://web.archive.org/web/20190824101042/http://cache.freescale.com/files/sensors/doc/app_note/AN3461.pdf
// Heading calculations taken from this app note:
// https://web.archive.org/web/20150513214706/http://www51.honeywell.com/aero/common/documents/myaerospacecatalog-documents/Defense_Brochures-documents/Magnetic__Literature_Application_notes-documents/AN203_Compass_Heading_Using_Magnetometers.pdf
  float roll = atan2(ay, az);
  float pitch = atan2(-ax, sqrt(ay * ay + az * az));
  float heading;
  if (my == 0)
    heading = (mx < 0) ? PI : 0;
    heading = atan2(mx, my);
  heading -= DECLINATION * PI / 180;
  if (heading > PI) heading -= (2 * PI);
  else if (heading < -PI) heading += (2 * PI);
  // Convert everything from radians to degrees:
  heading *= 180.0 / PI;
  pitch *= 180.0 / PI;
  roll  *= 180.0 / PI;
  Serial.print("Pitch, Roll: ");
  Serial.print(pitch, 2);
  Serial.print(", ");
  Serial.println(roll, 2);
  Serial.print("Heading: "); Serial.println(heading, 2);
The value I want is already the "heading ?"
Show the output of the program of Post-1.
Here's the output
G: -1.36, 0.49, 0.06 deg/s
A: 0.10, -0.03, 1.02 g
M: 0.16, 0.39, -0.24 gauss
Pitch, Roll: -5.86, -1.60
Heading: -103.73
Now, what do you want to extract from the given output information of Post-3?
I would like to have a 0-360° value
What are the inputs? What is the relation (formula) among the direction and the inputs?
The inputs are the value from the sensors; I would like to have i.e.:
0° = North
print value of the sensor in angle [0-360°] referenced to North
Probably something like this.
  float degrees_heading = 180.0 / PI * atan2(imu.mx, imu.my) ;
  if (degrees_heading < 0.0)
    degrees_heading += 360.0 ;
Do I need also to calibrate the sensor?
It works but not printing correct values, if I turn around Z axis (360°) It does not print correctly the angle
Probably.
Are you in Boulder, Colorado? If not, look up the declination for your location and use that.
Yes I changed with my location.
Does the sensor needs to calibrate ?
You must calibrate the magnetometer. This is a good tutorial: Tutorial: How to calibrate a compass (and accelerometer) with Arduino | Underwater Arduino Data Loggers
Even if the calibration is done, the code you have expects the sensor to be held level. If not, the reported heading will be wrong.
It is simple to implement tilt compensation, and code to do that (as well as to calibrate the magnetometer) can be found here: GitHub - jremington/LSM9DS1-AHRS: Mahony 3D fusion filter and tilt compensated compass, with sensor calibration code
I tried to follow the instruction on Adafruit : Simple Magnetic Calibration | Adafruit SensorLab - Magnetometer Calibration | Adafruit Learning System
Using the "Step 1 - Upload the SensorLab hardiron simplecal Example", then re upload the sketch but I got this value:
Keeping this as a 0 value = Heading: -142.93
Turn 90° ==> Heading: -104.81
Turn 180° ==> Heading: -89.56
Turn 270° ==> Heading: -175.0
Turn 360°==> -148.0
what am I doing wrong ?
Not enough information to guess what you did wrong, but the magnetometer is not calibrated. What offsets were determined, and how did you apply them? The offsets have to be put into the code that does the heading calculation.
Read all the instructions again, and execute the steps one by one, very carefully.
I'm trying to follow also the sketch from Adafruit : Adafruit calibration
Adafruit_SensorLab->calibration->mag_hardiron_simplecal
This is the output of the sketch:
Mag: (19.99, 34.93, 6.18) Hard offset: (15.62, 13.27, 15.13) Field: (34.24, 29.45, 38.37)
what do I have to do with this data ?
Tested also with Motion Sensor Calibration Tool and imucal sketch from Adafruit sensor lab:
Again, where do I have to put in my sketch the Magnetic offset ?
The corrections have to be applied somewhere. Where are they stored and applied?
Examples are given in the last link in reply #12
