Hey
I am trying to get a rotation vector out of my Arduino namo 33 ble.
I am Using the lib LSM9DS1 version 2 lib from git here
And i Have implemented the mahony and madgwick lib from
here
as many have done before.
but my problem is the when i am trying to output my rotation vector in yaw and have done a rotation of 90 degrees it only output around 38 - 48 degrees.
I dont know if it was my calibration that is off or what was wrong.
the filter and calculator class have been testet before with a wiimote controller and did work fine with that up untill the wiimote got stuck in the accelerometer.
even the madgwick lib seems not to work proberly or is it my sensor?
very much apreciate any suggestions since this is my a little part of my bachelor projeckt and should only have been a small part of the project and not a timeconsuming issue with getting the right orientation.
THX
Rasmus
**my code. **
Sketch:
#include <Arduino_LSM9DS1.h>
#include <TimeLib.h>
#include <MadgwickAHRS.h>
#include <SensorFusion.h>
#include <Filter.h>
#include <calc.h>
// for timestamp
#define TIMEHEADER "T"
#define TIMEREQUEST 7
unsigned long t = 0;
unsigned long mi = 0;
unsigned long last = 0;
// for sensor fusion
SF fusion;
float deltat = 0;
Madgwick mad;
Filter f;
Filter f2;
calc calculator;
f.setSamplePeriod(0.0042);
f.setkP(8);
f.setkI(0.000);
f.setBeta(0.001);
f2.setSamplePeriod(0.0042);
f2.setkP(8);
f2.setkI(0.000);
f2.setBeta(0.01);
mad.begin(238);
while (!Serial);
Serial.println("Started");
setSyncProvider(requestSync);
Serial.println("Waiting for sync message");
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
// /******************* For an improved accuracy run the DIY_Calibration_Accelerometer sketch first. ****************
//******************** Copy/Replace the lines below by the code output of the program ****************/
// Accelerometer code
IMU.setAccelFS(3);
IMU.setAccelODR(4);
IMU.setAccelOffset(-0.004423, -0.021684, -0.035664);
IMU.setAccelSlope (1.004703, 0.999619, 1.009910);
//******* FS Full Scale range 0:±2g | 1:±24g | 2: ±4g | 3: ±8g (default=2) ******
//******* ODR Output Data Rate range 0:off | 1:10Hz | 2:50Hz | 3:119Hz | 4:238Hz | 5:476Hz, (default=3)(not working 6:952Hz) ******
IMU.accelUnit = GRAVITY; // or METERPERSECOND2
///******* The gyroscope needs to be calibrated. Offset controls drift and Slope scales the measured rotation angle *********
//***************** Copy/Replace the lines below by the output of the DIY_Calibration_Gyroscope sketch ********************/
// Gyroscope code
IMU.setGyroFS(3);
IMU.setGyroODR(4);
IMU.setGyroOffset (0.225098, 0.559692, -2.038330);
IMU.setGyroSlope (1.179980, 1.130254, 1.146827);
//********* FS Full Scale setting 0: ±245°/s | 1: ±500°/s | 2: ±1000°/s | 3: ±2000°/s ****************************
//********* ODR Output Data Rate setting 0:off | 1:10Hz | 2:50Hz | 3:119Hz | 4:238Hz | 5:476Hz, (not working 6:952Hz) *******
IMU.gyroUnit= DEGREEPERSECOND; // DEGREEPERSECOND RADIANSPERSECOND REVSPERMINUTE REVSPERSECOND
// /***************** For a proper functioning of the magnetometer it needs to be calibrated ********************
//***************** Replace the lines below by the output of the DIY_Calibration_Magnetometer sketch ********************/
// Magnetometer code
IMU.setMagnetFS(3);
IMU.setMagnetODR(7);
IMU.setMagnetOffset(2.399902, 14.291992, -2.126465);
IMU.setMagnetSlope (0.995480, 1.149142, 1.180199);
//**** FS Full Scale range (0=±400 | 1=±800 | 2=±1200 | 3=±1600 (µT) *****
//**** ODR Output Data Rate range (6,7,8)=(40,80,400)Hz | not available on all chips (0..5): (0.625,1.25,2.5,5.0,10,20)Hz *****
IMU.magnetUnit = MICROTESLA; // GAUSS MICROTESLA NANOTESLA
float x, y, z;
float gx, gy, gz, mx, my, mz;
if (IMU.magnetAvailable()) // alias IMU.magneticFieldAvailable in library version 1.01
{ IMU.readMagnet(mx, my, mz); // alias IMU.readMagneticField in library version 1.01
if (IMU.gyroAvailable()) // alias IMU.gyroscopeAvailable
IMU.readGyro(gx, gy, gz); // alias IMU.readGyroscope
if (IMU.accelAvailable()) // alias IMU.accelerationAvailable in library version 1.01
{ IMU.readAccel(x, y, z); // alias IMU.readAcceleration in library version 1.01
// for time stamp
last = mi;
mi = millis();
if (Serial.available()) {
t = processSyncMessage();
t += (mi - last);
float gx1 = calculator.deg2Rad(gx);
float gy1 = calculator.deg2Rad(gy);
float gz1 = calculator.deg2Rad(gz);
f.UpdateMahony(gx1, gy1, gz1, x, y, z, mx, my, mz);
f2.UpdateMahony(gx1, gy1, gz1, x, y, z);
mad.updateIMU(gx, gy, gz, x, y, z);
//f.sensorFusion(gx,gy,gz,x,y,z);
//deltat = fusion.deltatUpdate();
if (t > 1357041600) {
//fusion.MadgwickUpdate(gx ,gy,gz,x,y,z,mx,my,mz,deltat);
fusion.MahonyUpdate(calculator.deg2Rad(gx),calculator.deg2Rad(gy),calculator.deg2Rad(gz),x,y,z,deltat);
float q1[4];
float q[4];
f.getQuaternion(q);
// q[0] = f.getq0();
// q[1] = f.getq1();
// q[2] = f.getq2();
// q[3] = f.getq3();
f2.getQuaternion(q1);
float rotV[3];
float rotV1[3];
calculator.quaternionToRotVec(q, rotV);
calculator.quaternionToRotVec(q1, rotV1);
Serial.print('[');
// Serial.print(IMU.getAccelODR());
// Serial.print(';');
// Serial.print(IMU.getGyroODR());
// Serial.print(IMU.getMagnetODR());
// Serial.print('\t');
Serial.print(t);
Serial.print(';');
Serial.print(mad.getRoll());
Serial.print(';');
Serial.print(mad.getPitch());
Serial.print(';');
Serial.print(mad.getYaw());
Serial.print(';');
Serial.print(fusion.getRoll());
Serial.print(';');
Serial.print(fusion.getPitch());
Serial.print(';');
Serial.print(fusion.getYaw());
Serial.print(';');
Serial.print(calculator.rad2Deg(rotV[0]));
Serial.print(';');
Serial.print(calculator.rad2Deg(rotV[1]));
Serial.print(';');
Serial.print(calculator.rad2Deg(rotV[2]));
Serial.print(';');
Serial.print(calculator.rad2Deg(rotV1[0]));
Serial.print(';');
Serial.print(calculator.rad2Deg(rotV1[1]));
Serial.print(';');
Serial.print(calculator.rad2Deg(rotV1[2]));
Serial.print(';');
Serial.print(x);
Serial.print(';');
Serial.print(y);
Serial.print(';');
Serial.print(z);
Serial.print(';');
Serial.print(gx);
Serial.print(';');
Serial.print(gy);
Serial.print(';');
Serial.print(gz);
Serial.print(';');
Serial.print(q[0]);
Serial.print(';');
Serial.print(q[1]);
Serial.print(';');
Serial.print(q[2]);
Serial.print(';');
Serial.print(q[3]);
Serial.print(';');
Serial.print(q1[0]);
Serial.print(';');
Serial.print(q1[1]);
Serial.print(';');
Serial.print(q1[2]);
Serial.print(';');
Serial.print(q1[3]);
Serial.println(']');
unsigned long processSyncMessage() {
unsigned long pctime;
const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
if (Serial.find(TIMEHEADER)) {
pctime = Serial.parseInt();
if ( pctime >= DEFAULT_TIME) { // check the integer is a valid time (greater than Jan 1 2013)
setTime(pctime); // Sync Arduino clock to the time received on the serial port
return pctime;
time_t requestSync()
Serial.write(TIMEREQUEST);
return 0; // the time will be sent later in response to serial mesg
Filter.cpp
#include "Filter.h"
#include <math.h>
Filter::Filter() :sPeriod{ 0 }, kP{ 1 }, kI{ 0 } {
quarternion[0] = 1;
quarternion[1] = 0;
quarternion[2] = 0;
quarternion[3] = 0;
quarternionM[0] = 1;
quarternionM[1] = 0;
quarternionM[2] = 0;
quarternionM[3] = 0;
intError[0] = 0;
intError[1] = 0;
intError[2] = 0;
angleX = 0;
angleY = 0;
angleZ = 0;
Beta = 0;
Filter::Filter(float samplePeriod) :sPeriod{ samplePeriod }, kP{ 1 }, kI{ 0 } {
quarternion[0] = 1;
quarternion[1] = 0;
quarternion[2] = 0;
quarternion[3] = 0;
intError[0] = 0;
intError[1] = 0;
intError[2] = 0;
angleX = 0;
angleY = 0;
angleZ = 0;
Beta = 0;
Filter::Filter(float samplePeriod, float proportionalGain) :sPeriod{ samplePeriod }, kP{ proportionalGain }, kI{ 0 }{
quarternion[0] = 1;
quarternion[1] = 0;
quarternion[2] = 0;
quarternion[3] = 0;
intError[0] = 0;
intError[1] = 0;
intError[2] = 0;
angleX = 0;
angleY = 0;
angleZ = 0;
Beta = 0;
Filter::Filter(float samplePeriod, float proportionalGain, float integralGain) : sPeriod{ samplePeriod }, kP{ proportionalGain }, kI{ integralGain } {
quarternion[0] = 1;
quarternion[1] = 0;
quarternion[2] = 0;
quarternion[3] = 0;
intError[0] = 0;
intError[1] = 0;
intError[2] = 0;
angleX = 0;
angleY = 0;
angleZ = 0;
Beta = 0;
Filter::~Filter() {};
void Filter::UpdateMadwick(float gx, float gy, float gz, float ax, float ay, float az) {
float q1 = quarternionM[0], q2 = quarternionM[1], q3 = quarternionM[2], q4 = quarternionM[3]; // short name local variable for readability
float norm;
float s1, s2, s3, s4;
float qDot1, qDot2, qDot3, qDot4;
// Auxiliary variables to avoid repeated arithmetic
float _2q1 = 2.0f * q1;
float _2q2 = 2.0f * q2;
float _2q3 = 2.0f * q3;
float _2q4 = 2.0f * q4;
float _4q1 = 4.0f * q1;
float _4q2 = 4.0f * q2;
float _4q3 = 4.0f * q3;
float _8q2 = 8.0f * q2;
float _8q3 = 8.0f * q3;
float q1q1 = q1 * q1;
float q2q2 = q2 * q2;
float q3q3 = q3 * q3;
float q4q4 = q4 * q4;
// Normalise accelerometer measurement
norm = (float)sqrt(ax * ax + ay * ay + az * az);
if (norm == 0.0f) return; // handle NaN
norm = 1 / norm; // use reciprocal for division
ax *= norm;
ay *= norm;
az *= norm;
// Gradient decent algorithm corrective step
s1 = _4q1 * q3q3 + _2q3 * ax + _4q1 * q2q2 - _2q2 * ay;
s2 = _4q2 * q4q4 - _2q4 * ax + 4.0f * q1q1 * q2 - _2q1 * ay - _4q2 + _8q2 * q2q2 + _8q2 * q3q3 + _4q2 * az;
s3 = 4.0f * q1q1 * q3 + _2q1 * ax + _4q3 * q4q4 - _2q4 * ay - _4q3 + _8q3 * q2q2 + _8q3 * q3q3 + _4q3 * az;
s4 = 4.0f * q2q2 * q4 - _2q2 * ax + 4.0f * q3q3 * q4 - _2q3 * ay;
norm = 1.0f / (float)sqrt(s1 * s1 + s2 * s2 + s3 * s3 + s4 * s4); // normalise step magnitude
s1 *= norm;
s2 *= norm;
s3 *= norm;
s4 *= norm;
// Compute rate of change of quaternion
qDot1 = 0.5f * (-q2 * gx - q3 * gy - q4 * gz) - Beta * s1;
qDot2 = 0.5f * (q1 * gx + q3 * gz - q4 * gy) - Beta * s2;
qDot3 = 0.5f * (q1 * gy - q2 * gz + q4 * gx) - Beta * s3;
qDot4 = 0.5f * (q1 * gz + q2 * gy - q3 * gx) - Beta * s4;
// Integrate to yield quaternion
q1 += qDot1 * sPeriod;
q2 += qDot2 * sPeriod;
q3 += qDot3 * sPeriod;
q4 += qDot4 * sPeriod;
norm = 1.0f / (float)sqrt(q1 * q1 + q2 * q2 + q3 * q3 + q4 * q4); // normalise quaternion
quarternionM[0] = q1 * norm;
quarternionM[1] = q2 * norm;
quarternionM[2] = q3 * norm;
quarternionM[3] = q4 * norm;
void Filter::UpdateMahony(float gx, float gy, float gz, float ax, float ay, float az) {
float q1 = quarternion[0] , q2 = quarternion[1] , q3 = quarternion[2] , q4 = quarternion[3]; // short name local variable for readability
float norm;
float vx, vy, vz;
float ex, ey, ez;
float pa, pb, pc;
norm = (float)sqrt((ax * ax) + (ay * ay) + (az * az));
if (norm == 0) return; // handle NaN
ax *= norm;
ay *= norm;
az *= norm;
//printf("ax : %f ay : %f az : %f\n", ax, ay, az);
// Estimated direction of gravity
vx = 2.0 * ((q2 * q4 ) - (q1 * q3));
vy = 2.0 * ((q1 * q2 ) + (q3 * q4));
vz = (q1 * q1 ) - (q2 * q2 ) - (q3 * q3 ) + (q4 * q4);
//printf("vx : %f vy : %f vz : %f\n", vx, vy, vz);
// Error is cross product between estimated direction and measured direction of gravity
ex = ((ay * vz ) - (az * vy));
ey = ((az * vx ) - (ax * vz));
ez = ((ax * vy ) - (ay * vx));
if (kI > 0)
intError[0] += ex; // accumulate integral error
intError[1] += ey;
intError[2] += ez;
intError[0] = 0.0f; // prevent integral wind up
intError[1] = 0.0f;
intError[2] = 0.0f;
// Apply feedback terms
gx = gx + (kP * ex ) + (kI * intError[0]);
gy = gy + (kP * ey ) + (kI * intError[1]);
gz = gz + (kP * ez ) + (kI * intError[2]);
//printf("gx : %f gy : %f gz : %f\n", gx, gy, gz);
// Integrate rate of change of quaternion
pa = q2;
pb = q3;
pc = q4;
q1 = q1 + (((-q2 * gx) - (q3 * gy ) - (q4 * gz)) * (0.5 * sPeriod));
q2 = pa + (((q1 * gx) + (pb * gz) - (pc * gy)) * (0.5 * sPeriod));
q3 = pb + (((q1 * gy) - (pa * gz) + (pc * gx)) * (0.5 * sPeriod));
q4 = pc + (((q1 * gz) + (pa * gy) - (pb * gx)) * (0.5 * sPeriod));
// Normalise quaternion
norm = (float)sqrt((q1 * q1) + (q2 * q2) + (q3 * q3) + (q4 * q4));
norm = 1.0f / norm;
quarternion[0] = q1 * norm;
quarternion[1] = q2 * norm;
quarternion[2] = q3 * norm;
quarternion[3] = q4 * norm;
//printf("Quaternion q1: %f q2: %f q3: %f q4: %f\n", quarternion[0], quarternion[1], quarternion[2], quarternion[3]);
void Filter::UpdateMahony(float gx, float gy, float gz, float ax, float ay, float az, float mx, float my, float mz)
float norm;
float hx, hy, bx, bz;
float vx, vy, vz, wx, wy, wz;
float ex, ey, ez;
float pa, pb, pc;
float q1q2 = q1 * q2;
float q1q3 = q1 * q3;
float q1q4 = q1 * q4;
float q2q3 = q2 * q3;
float q2q4 = q2 * q4;
float q3q4 = q3 * q4;
ax *= norm;
ay *= norm;
az *= norm;
// Normalise magnetometer measurement
norm = (float)sqrt(mx * mx + my * my + mz * mz);
mx *= norm;
my *= norm;
mz *= norm;
// Reference direction of Earth's magnetic field
hx = 2 * mx * (0.5 - q3q3 - q4q4) + 2 * my * (q2q3 - q1q4) + 2 * mz * (q2q4 + q1q3);
hy = 2 * mx * (q2q3 + q1q4) + 2 * my * (0.5f - q2q2 - q4q4) + 2 * mz * (q3q4 - q1q2);
bx = (float)sqrt((hx * hx) + (hy * hy));
bz = 2 * mx * (q2q4 - q1q3) + 2 * my * (q3q4 + q1q2) + 2 * mz * (0.5f - q2q2 - q3q3);
// Estimated direction of gravity and magnetic field
vx = 2 * (q2q4 - q1q3);
vy = 2 * (q1q2 + q3q4);
vz = q1q1 - q2q2 - q3q3 + q4q4;
wx = 2 * bx * (0.5 - q3q3 - q4q4) + 2 * bz * (q2q4 - q1q3);
wy = 2 * bx * (q2q3 - q1q4) + 2 * bz * (q1q2 + q3q4);
wz = 2 * bx * (q1q3 + q2q4) + 2 * bz * (0.5 - q2q2 - q3q3);
ex = (ay * vz - az * vy) + (my * wz - mz * wy);
ey = (az * vx - ax * vz) + (mz * wx - mx * wz);
ez = (ax * vy - ay * vx) + (mx * wy - my * wx);
if (kI > 0)
intError[1] += ey;
intError[2] += ez;
intError[0] = 0.0; // prevent integral wind up
intError[1] = 0.0;
intError[2] = 0.0;
gx = gx + kP * ex + kI * intError[0];
gy = gy + kP * ey + kI * intError[1];
gz = gz + kP * ez + kI * intError[2];
pa = q2;
pb = q3;
pc = q4;
q1 = q1 + (-q2 * gx - q3 * gy - q4 * gz) * (0.5 * sPeriod);
q2 = pa + (q1 * gx + pb * gz - pc * gy) * (0.5 * sPeriod);
q3 = pb + (q1 * gy - pa * gz + pc * gx) * (0.5 * sPeriod);
q4 = pc + (q1 * gz + pa * gy - pb * gx) * (0.5 * sPeriod);
norm = (float)sqrt(q1 * q1 + q2 * q2 + q3 * q3 + q4 * q4);
norm = 1.0 / norm;
void Filter::updateIMU(float ax, float ay, float az, float gx, float gy, float gz,float T) {
float norm;
float vx, vy, vz;
float ex, ey, ez;
float filtCoef = 0.75f, filtCoef2 = 0.75f;
float ax0, ay0, az0, gx0, gy0, gz0;
float q0 = quarternion[0];
float q1 = quarternion[1];
float q2 = quarternion[2];
float q3 = quarternion[3];
float kP = 5.0f;
float Ki = 0.0005;
float halfT = 0.5f;
ax0 = ax;
ay0 = ay;
az0 = az;
gx0 = gx;
gy0 = gy;
gz0 = gz;
// normalise the measurements
ax = ax / norm;
ay = ay / norm;
az = az / norm;
// estimated direction of gravity
vx = 2 * (q1 * q3 - q0 * q2);
vy = 2 * (q0 * q1 + q2 * q3);
vz = q0 * q0 - q1 * q1 - q2 * q2 + q3 * q3;
//printf("estimated direction of gravity vx = %f vy = %f vz = %f",vx,vy,vz);
// error is sum of cross product between reference direction of field and direction measured by sensor
ex = (ay * vz - az * vy);
ey = (az * vx - ax * vz);
ez = (ax * vy - ay * vx);
// integral error scaled integral gain
exInt = filtCoef * exInt + (1 - filtCoef) * ex;
eyInt = filtCoef * eyInt + (1 - filtCoef) * ey;
ezInt = filtCoef * ezInt + (1 - filtCoef) * ez;
// adjusted gyroscope measurements
gx = filtCoef2 * gx + (1 - filtCoef2) * (kP * ex + Ki * exInt) / T;
gy = filtCoef2 * gy + (1 - filtCoef2) * (kP * ey + Ki * eyInt) / T;
gz = filtCoef2 * gz + (1 - filtCoef2) * (kP * ez + Ki * ezInt) / T;
// integrate quaternion rate and normalise
q0 = q0 + (-q1 * gx - q2 * gy - q3 * gz) * halfT * T;
q1 = q1 + (q0 * gx + q2 * gz - q3 * gy) * halfT * T;
q2 = q2 + (q0 * gy - q1 * gz + q3 * gx) * halfT * T;
q3 = q3 + (q0 * gz + q1 * gy - q2 * gx) * halfT * T;
norm = (float)sqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
q0 = q0 / norm;
q1 = q1 / norm;
q2 = q2 / norm;
q3 = q3 / norm;
//printf("q0 = %f, q1 = %f, q2 = %f, q3 = %f\n", q0, q1, q2, q3);
quarternion[0] = q0;
quarternion[1] = q1;
quarternion[2] = q2;
quarternion[3] = q3;
void Filter::sensorFusion(float gx, float gy, float gz, float ax, float ay, float az) {
angleX = 0.98 * (angleX + gx * sPeriod) + 0.02 * ax;
angleY = 0.98 * (angleY + gy * sPeriod) + 0.02 * ay;
angleZ = 0.98 * (angleZ + gz * sPeriod) + 0.02 * az;
float Filter::kalman(float U) {
K = (P * H) / (H * P * H + R);
uHat = uHat + K * (U - H * uHat);
P = (1 - K * H) * P + Q;
return uHat;
void Filter::setSamplePeriod(float samplePeriod) {
this->sPeriod = samplePeriod;
void Filter::setkP(float proportionalGain) {
this->kP = proportionalGain;
void Filter::setkI(float integralGain) {
this->kI = integralGain;
void Filter::setBeta(float beta) {
this->Beta = beta;
void Filter::setQuaternion(float Quarternion[4]) {
quarternion[0] = Quarternion[0];
quarternion[1] = Quarternion[1];
quarternion[2] = Quarternion[2];
quarternion[3] = Quarternion[3];
void Filter::setIntegralError(float intergralError[3]) {
intError[0] = intergralError[0];
intError[1] = intergralError[1];
intError[2] = intergralError[2];
float Filter::getSamplePeriod() {
return sPeriod;
float Filter::getProportionalGain() {
return kP;
float Filter::getIntegralGain() {
return kI;
float Filter::getBeta() {
return Beta;
void Filter::getQuaternion(float quat[4]) {
quat[0] = quarternion[0];
quat[1] = quarternion[1];
quat[2] = quarternion[2];
quat[3] = quarternion[3];
void Filter::getQuaternionMad(float quatMad[4]) {
quatMad[0] = quarternionM[0];
quatMad[1] = quarternionM[1];
quatMad[2] = quarternionM[2];
quatMad[3] = quarternionM[3];
void Filter::getIntegralError(float intErr[3]) {
intErr[0] = intError[0];
intErr[1] = intError[1];
intErr[2] = intError[2];
float Filter::getAx() {
return angleX;
float Filter::getAy() {
return angleY;
float Filter::getAz() {
return angleZ;
void Filter::updateQuaternionOff(float quaternionOffSet[4]) {
quarternion[0] += quaternionOffSet[0];
quarternion[1] += quaternionOffSet[1];
quarternion[2] += quaternionOffSet[2];
quarternion[3] += quaternionOffSet[3];
calc.cpp
#include "calc.h"
#define _USE_MATH_DEFINES
calc::calc() {};
calc::~calc() {};
void calc::eulToQuaternion(float roll, float pitch, float yaw, float quat[4]) {
float cy = cos(yaw * 0.5);
float sy = sin(yaw * 0.5);
float cp = cos(pitch * 0.5);
float sp = sin(pitch * 0.5);
float cr = cos(roll * 0.5);
float sr = sin(roll * 0.5);
quat[0] = cr * cp * cy + sr * sp * sy;
quat[1] = sr * cp * cy - cr * sp * sy;
quat[2] = cr * sp * cy + sr * cp * sy;
quat[3] = cr * cp * sy - sr * sp * cy;
void calc::quaternionToEul(float quaternion[4],float eul[3]) {
//double pi = 2 * asin(1.0);
// roll (x-axis rotation)
float sinr_cosp = 2 * (quaternion[0] * quaternion[1] + quaternion[2] * quaternion[3]);
float cosr_cosp = 1 - 2 * (quaternion[1] * quaternion[1] + quaternion[2] * quaternion[2]);
eul[0] = atan2(sinr_cosp, cosr_cosp);
// pitch (y-axis rotation)
double sinp = 2 * (quaternion[0] * quaternion[2] - quaternion[3] * quaternion[1]);
if (std::abs(sinp) >= 1)
eul[1] = copysign(pi / 2, sinp); // use 90 degrees if out of range
eul[1] = asin(sinp);
// yaw (z-axis rotation)
double siny_cosp = 2 * (quaternion[0] * quaternion[3] + quaternion[1] * quaternion[2]);
double cosy_cosp = 1 - 2 * (quaternion[2] * quaternion[2] + quaternion[3] * quaternion[3]);
eul[2] = atan2(siny_cosp, cosy_cosp);
void calc::quaternionToRotVec(float quaternion[4],float rotVec[3]) {
float q0 = quaternion[0];
float q1 = quaternion[1];
float q2 = quaternion[2];
float q3 = quaternion[3];
float norm = (float)sqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
q0 = q0 / norm;
q1 = q1 / norm;
q2 = q2 / norm;
q3 = q3 / norm;
float theata = 2 * acos(q0);
float angle = theata / sin(theata / 2);
rotVec[0] = angle * q1;
rotVec[1] = angle * q2;
rotVec[2] = angle * q3;
void calc::quatToEul(float quaternion[4],float eul[3]) {
calc c;
double sqw = q0 * q0;
double sqx = q1 * q1;
double sqy = q2 * q2;
double sqz = q3 * q3;
double unit = sqx + sqy + sqz + sqw; // if normalised is one, otherwise is correction factor
double test = q1 * q2 + q3 * q0;
if (test > 0.499 * unit) { // singularity at north pole
eul[0] = c.rad2Deg(2 * atan2(q1, q1));
eul[1] = c.rad2Deg(pi / 2);
eul[2] = c.rad2Deg(0);
else if (test < -0.499 * unit) { // singularity at south pole
eul[0] = c.rad2Deg(-2 * atan2(q1, q0));
eul[1] = c.rad2Deg(-pi / 2);
else{
eul[0] = c.rad2Deg(atan2(2 * q2 * q0 - 2 * q1 * q3, sqx - sqy - sqz + sqw));
eul[1] = c.rad2Deg(asin(2 * test / unit));
eul[2] = c.rad2Deg(atan2(2 * q1 * q0 - 2 * q2 * q3, -sqx + sqy - sqz + sqw));
rotMatrix calc::quaternionToMatrix(float quaternion[4]) {
rotMatrix matrix;
matrix.XX = 2 * (q0 * q0 + q1 * q1) - 1;
matrix.XY = 2 * (q1 * q2 - q0 * q3);
matrix.XZ = 2 * (q1 * q3 + q0 * q2);
matrix.YX = 2 * (q1 * q2 + q0 * q3);
matrix.YY = 2 * (q0 * q0 + q2 * q2) - 1;
matrix.YZ = 2 * (q2 * q3 - q0 * q1);
matrix.ZX = 2 * (q1 * q3 - q0 * q2);
matrix.ZY = 2 * (q2 * q3 + q0 * q1);
matrix.ZZ = 2 * (q0 * q0 + q3 * q3) - 1;
return matrix;
float calc::deg2Rad(float deg) {
return (deg * pi / 180);
float calc::rad2Deg(float rad) {
return (rad * 180 / pi);
