Hi guys,
I am trying to convert an array of integers to an integer. For example, int Array1=[123] --> int num1 =123.
Atoi() doesn't work...
Do you know some way to do it?
Thanks!
do you mean array1 [1, 2, 3] (ie 3 separate number?)
array[0]*100 + array[1]*10 + array[2]
generally you can put this in a loop for the same effect
int sum = 0;
for (uint8_t i=0; i<MAX_DIGITS; i++)
sum = (sum*10)+array[i];
"I am trying to convert an array of integers to an integer. For example, int Array1=[123] --> int num1 =123."
It would help if you ask a sensible question. This is just nonsense.
