Convert ASCII hex String to int
Hello,
I'm trying to convert a ASCII String containing HEX color values to something useful like integers.
The code passes a HEX colorcode as String UrlColor = server.arg ("Color") from a web page.
First the %23 ("#"sign) is removed to only get the hex color in a String object.
Now i would like to change this String Object to set the color of RGB leds.
This is where i get stuck, how to get the 3 blocks of true (HEX,DEC,BIN) Integer from a string?
The Code So Far
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
//WiFi Settings
const char* ssid = "SIDD";
const char* password = "PASS";
//MDNS Settings
const char* MSDNhostname = "esp8266";
// Url variables
String UrlColor = "ff0000";
String Range = "50";
// Initialize Webserver And MDNS
ESP8266WebServer server(80);
MDNSResponder mdns;
void setup ()
  //Setup Serial interface
  //Setup WiFi
  WiFi.begin(ssid, password);
  Serial.print("Connecting To WiFi Network: ");
  Serial.println(ssid);
  // Wait For WiFi Connection
  while (WiFi.status() != WL_CONNECTED)
      delay(250);
      Serial.print(".");
  Serial.println("");
  // Show Connection info
  Serial.print("Connected  To Wifi Network: ");
  //Start WebServer
  server.begin();
  Serial.print("HTTP Server: ");
  Serial.print ("http://");
  Serial.println (WiFi.localIP());
  //Start MDNSserver
  mdns.begin(MSDNhostname, WiFi.localIP());
  Serial.print("MDNS Server: ");
  Serial.print (MSDNhostname);
  Serial.println (".local");
  //WebServer Calls
  server.on("/", handleRoot);
  server.onNotFound(handleNotFound);
void loop(void)
  //Allow ESP to MultiTask and prevent code from Blocking WiFi functions etc.
  yield();
  //Handle WebServerClients
  server.handleClient();
void handleRoot() {
  if (server.hasArg ("Color"))
    //Store server.arg("Color") to String UrlColor
      UrlColor = server.arg ("Color");
    // Remove first 3 places of UrlColor ("#" = %23) to get a HexColor String
      UrlColor.remove(0, 3);
  //Show Received UrlColor String containing HEX values on Serial
  Serial.print("Color Received From Browser: ");
  Serial.println(UrlColor);
  if (server.hasArg ("Range"))
    //Store server.arg("Range") to String Range
      Range = server.arg ("Range");
  //Show Received Range String as integer on Serial
  Serial.print("Range Received From Browser: ");
  Serial.println(Range.toInt());
  String HtmlDocument = "<!DOCTYPE html>";
        HtmlDocument += "<html>";
        HtmlDocument += "<body>";
        HtmlDocument += "<form action='/' method='post'>";
        HtmlDocument += "<input type='Range' onchange='this.form.submit()' name='Range' min='0' max='255'value='"+Range+"' style='width: 98%;'>";
        HtmlDocument += "
        HtmlDocument += "<input type='color' onchange='this.form.submit()' name='Color' value='#"+UrlColor+"' style='width: 98%;'>";
        HtmlDocument += "</form>";
        HtmlDocument += "</body>";
        HtmlDocument += "</html>";
  server.send(200, "text/html", HtmlDocument);
void handleNotFound(){
          HtmlDocument += "<h1>File Not Found !</h1>";
          HtmlDocument += "<p>URI: "+server.uri()+"</p>";
  server.send(404, "text/html", HtmlDocument);
Thanks in Advance
You are trying to convert a useless instance of the String class to something useful. You first need to extract the useful data from the String instance.
char whatYouShouldHaveUsed[40];
uselessStringInstance.toCharArray(whatYouShouldHaveUsed, sizeof(whatYouShouldHaveUsed)-1);
Then, you can use strtoul() to convert whatYouShouldHaveUsed to an unsigned long.
