Hi guys
How can i move the contents of one string into another string ?
Hi guys
Do you mean string or do you mean String ?
The topic title says one thing, your question say another
There is a vital difference
Do you mean String or string (note cases)?
Assuming a character array (string) then you can use strcpy or strncpy.
OK UKHeliBob beat me to asking ![]()
String
Use the assignment operator
Better still, don't use Strings
String thisString;
String thatString = "something";
this String = thatString;
I want to move the "Credit" content, which is of type String, into "SendMessage", which is of type char*, so that I can send it to someone.
#include <Sim800L.h>
#define RX 10
#define TX 11
Sim800L GSM(RX, TX);
String PhoneNumber = "+ZZ***********" ;
char* ReceiveMessage ;
char* SendMessage ;
String Credit ;
String Cache ;
boolean Allow = false;
GSM.begin(9600);
Basic_Settings();
if(GSM.available())
ReceiveMessage = GSM.readStringUntil('\n');
Serial.println(ReceiveMessage);
if(ReceiveMessage == "C\r")
GSM.println("AT+CUSD=1,\"*141*1#\"");
Allow = true;
if(Allow)
Cache = ReceiveMessage.substring(ReceiveMessage.indexOf("Credit"));
if(Cache.substring(0,6) == "Credit")
Credit = Cache.substring(0,18);
Sender_Message();
Allow = false;
void Sender_Message()
GSM.sendSms(PhoneNumber , SendMessage);
void Basic_Settings()
GSM.println("AT");
GSM.println("AT+CMGF=1");
GSM.println("AT+CNMI=1,2,0,0,0");
GSM.println("AT+CSMP=17,167,2,25\r");
This is a String
char* SendMessage ;
and this a "pointer to char".
Two objects completely different...
In order to copy content of Credit to SendMessage you have to reallocate enought memory to contains the number of chars of Credit + 1.
Not simple and surely not reccommendable for newbies (as in general).
Why you don't use two String vars (or two char arrays) instead?
Because this is not possible.
@mstfa, and why not?
"don't know how" it's not exactly the same as "it's not possible"
String SendMessage = "This is possible";
GSM.sendSms(PhoneNumber , SendMessage.c_str() );
I changed the program this way and got the answer.
#define RX 10
#define TX 11
char* PhoneNumber = "+ZZ***********" ;
String ReceiveMessage ;
char* SendMessage ;
String Credit ;
String Cache ;
GSM.begin(9600);
Basic_Settings();
if(GSM.available())
Allow = true;
if(Allow)
SendMessage = Credit.c_str() ;
Sender_Message();
Allow = false;
GSM.println("AT");
Thank you for your help !
