Hi there!
I have bin searching the forum but could not find anything in the subject.
I is there a way to convert an integer value like 12 into a string in binary format like "00001100" ?
The idea is to send the binary string value to a LCD display.
Thank you for your replies fellows.
TBAr I am using the LCD4bit library and it looks like passing a "BIN" to the function does not work.
However I will try to use the bitread() approach instead.
I had to do the same thing with a 16 bit word on an LCD.
lcd.print(data, BIN); //this works, but like TBAr said, there are no leading zeros, so it looks messy when you're displaying a bunch of binary numbers. So I used the bitWrite(x,bitn) method. This just seems like it must use a lot of processor time because it has to write a value to the LCD for each bit one at a time, but it works.
lcd.setCursor(0,1); // set to first character bottom line
for (int i=15; i>=0; i--)
if (bitRead(value,i)==1) lcd.print ("1"); else lcd.print ("0");
this can be shortened to:
if (bitRead(value,i)) lcd.print ("1"); else lcd.print ("0");
