Convert int to byte array
Hello,
First day with the Arduino Mega2560.
I'm trying to display some data that's recieved by the serial line and display it on a 4x7 segment display.
Currently my code will only display the last 2 digits correctly. So if I enter in 1234, the output on the 4x7 segment display will be 0034.
if I enter in 123 the output will be 0023 and so on.
I'm not sure why it's doing this. I'm familiar with C++, but not C, so I may have some syntax wrong.
Here is my current code:
void displayNumber(int originalNumber)
  int newNumber=originalNumber;
  int digit=0;
  if (bigEndian) {
    for (byte segSetup = segmentDisplayCount; segSetup > 0; --segSetup) {
      digit = newNumber%10;
//If I print out the value of newNumber here, after the 2nd loop, 123/10=0 for some reason.
      if (newNumber > 0) {
        setNumber(segSetup-1, digit);
      else {
        setNumber(segSetup-1, 0);
      newNumber /= 10;
If I manually do the conversion with:
  dig1 = num / 1000;
  num = num - (dig1 * 1000);
  dig2 = num / 100;
  num = num - (dig2 * 100);
  dig3 = num / 10;
  dig4 = num - (dig3 *10);
It works fine.
Can anyone tell me why this is happening, or offer some different code that I could test? I've been stuck on this for hours trying different methods of splitting the int up, but always leads to dead ends :(.
No, it isn't. That is SOME of your code. We can't see what segmentDisplayCount is.
originalNumber is a pass by value argument. There is no reason to make a copy of it. The variable that held the value passed to the function can not possibly be impacted by what the function does.
There must be something else going on.
The full code is quite lengthy, but I've pasted it here.
// Segment labelling:
//        A
//     F |  | B
//       ---- G
//     E |  | C
//       ----   .H
//        D
// Pins:
//             12        7
//              1       6
//Pins on 4x7 Segment Display:
// Pin 1:  E
// Pin 2:  D
// Pin 3:  H
// Pin 4:  C
// Pin 5:  G
// Pin 6:  4th 7 Segment
// Pin 7:  B
// Pin 8:  3rd 7 Segment
// Pin 9:  2nd 7 Segment
// Pin 10: F
// Pin 11: A
// Pin 12: 1st 7 Segment
byte segmentPinCount=8; //Includes the . (Decimal place)
byte segmentDisplayCount=4; //How many 7 segment displays do we have?
byte sevenSegmentPins[8] = {2,3,4,5,6,7,8,9}; // A, B, C, D, E, F, G, H
byte sevenSegmentCathodePins[4]={10,11,14,16}; //1st, 2nd, 3rd, 4th
int delayTime = 4; // Time in ms to allow for pin state change.
boolean bigEndian = true; //If the display can't fit the number, which end should we show?
boolean serialCom = true; //Allow serial communication.
int num=0;
int dig1 = 0;
int dig2 = 0;
int dig3 = 0;
int dig4 = 0;
byte sevenSegmentDisplay[36][8] = {
  //A B C D E F G H
  { 1,1,1,1,1,1,0,0 },  // = 0
  { 0,1,1,0,0,0,0,0 },  // = 1
  { 1,1,0,1,1,0,1,0 },  // = 2
  { 1,1,1,1,0,0,1,0 },  // = 3
  { 0,1,1,0,0,1,1,0 },  // = 4
  { 1,0,1,1,0,1,1,0 },  // = 5
  { 1,0,1,1,1,1,1,0 },  // = 6
  { 1,1,1,0,0,0,0,0 },  // = 7
  { 1,1,1,1,1,1,1,0 },  // = 8
  { 1,1,1,0,0,1,1,0 },  // = 9
  { 1,1,1,0,1,1,1,0 },  // = A
  { 0,0,1,1,1,1,1,0 },  // = B
  { 1,0,0,1,1,1,0,0 },  // = C
  { 0,1,1,1,1,0,1,0 },  // = D
  { 1,0,1,0,1,1,1,0 },  // = E
  { 1,0,0,0,1,1,1,0 },  // = F
  { 0,0,0,0,0,0,0,0 }   // = Clear
  { 1,0,0,1,0,0,0,0 }   // = =
  { 0,0,0,0,0,1,0,0 }   // = '
  { 1,1,1,1,1,1,0,1 },  // = 0.
  { 0,1,1,0,0,0,0,1 },  // = 1.
  { 1,1,0,1,1,0,1,1 },  // = 2.
  { 1,1,1,1,0,0,1,1 },  // = 3.
  { 0,1,1,0,0,1,1,1 },  // = 4.
  { 1,0,1,1,0,1,1,1 },  // = 5.
  { 1,0,1,1,1,1,1,1 },  // = 6.
  { 1,1,1,0,0,0,0,1 },  // = 7.
  { 1,1,1,1,1,1,1,1 },  // = 8.
  { 1,1,1,0,0,1,1,1 },  // = 9.
  { 1,1,1,0,1,1,1,1 },  // = A.
  { 0,0,1,1,1,1,1,1 },  // = B.
  { 1,0,0,1,1,1,0,1 },  // = C.
  { 0,1,1,1,1,0,1,1 },  // = D.
  { 1,0,1,0,1,1,1,1 },  // = E.
  { 1,0,0,0,1,1,1,1 },  // = F.
  { 0,0,0,0,0,0,0,1 }   // = Clear. (With dot)
  for (byte pinSetup = 0; pinSetup < segmentPinCount; ++pinSetup) {
    pinMode(sevenSegmentPins[pinSetup], OUTPUT); //Setup our control pins for output.
  for (byte segSetup = 0; segSetup < segmentDisplayCount; ++segSetup) {
    pinMode(sevenSegmentCathodePins[segSetup], OUTPUT); //Setup our cathode power pins for each 7 segment display.
  if (serialCom) { Serial.begin(9600); } //Allow serial communication.
    digitalWrite(sevenSegmentCathodePins[segSetup], HIGH); //Reset cathode control pins.
if (Serial.available() > 0)
  num = Serial.parseInt();
  Serial.println(num);
  dig1 = num / 1000;
  dig2 = num / 100;
  dig3 = num / 10;
//displayNumber(num);
  setNumber(3, dig4);
  setNumber(2, dig3);
  setNumber(1, dig2);
  setNumber(0, dig1);
  int digit=0;
  if (bigEndian) {
      //Serial.println(newNumber);
      //digit = ((originalNumber/(10^segSetup))%10);
      else {
      newNumber /= 10;
void setNumber(byte pin, int x)
  digitalWrite(sevenSegmentCathodePins[pin], LOW);
   switch(x){
     case 1:
       for (byte segIndex = 0; segIndex < segmentPinCount; ++segIndex) {
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[1][segIndex]);
     case 2:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[2][segIndex]);
     case 3:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[3][segIndex]);
     case 4:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[4][segIndex]);
     case 5:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[5][segIndex]);
     case 6:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[6][segIndex]);
     case 7:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[7][segIndex]);
     case 8:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[8][segIndex]);
     case 9:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[9][segIndex]);
     case 0:
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[0][segIndex]);
     case 10: //A
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[10][segIndex]);
     case 11: //B
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[11][segIndex]);
     case 12: //C
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[12][segIndex]);
     case 13: //D
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[13][segIndex]);
     case 14: //E
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[14][segIndex]);
     case 15: //F
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[15][segIndex]);
     case 36: //Clear . (With dot)
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[36][segIndex]);
     default: //Clear
         digitalWrite(sevenSegmentPins[segIndex], sevenSegmentDisplay[16][segIndex]);
   delay (delayTime);
   digitalWrite( sevenSegmentCathodePins[pin], HIGH);
I took your function, and made some minor tweaks, just to test it's functionality:
  displayNumber(1234);
void displayNumber(int number)
  Serial.print("number: ");
  Serial.println(number);
  int digit=0;
  for (byte s = 4; s > 0; --s)
    digit = number%10;
    number /= 10;
    Serial.print("digit: ");
    Serial.println(digit);
Running this, I get:
number: 1234
digit: 4
number: 123
digit: 3
number: 12
digit: 2
number: 1
digit: 1
number: 0
So, you need to look at how you are using the function.
It's a good thing that this got commented out and replaced.
In C++ (and the Arduino programming language is just glorified C++), the ^ symbol does not stand for exponentiation.
In fact, there is no built-in function for integer exponentiation. You have to write your own, using a loop or some such.
Figured it out. The problem was the code I was using to debug above was changing the variable I was passing into the function. It was only passing in 34 in the first place. I feel like an idiot, that's something I should have checked first, lol.
Thanks for your help PaulS, I wouldn't have thought to look there unless I had used your code.
Can you overload the ^ opperator in the sketchup IDE? Also, I noticed if I get errors, it's refering to a CPP file somewhere (and not the actual lines in my sketch up). I've Googled around a little bit and can't find the file's location (I'm running Ubuntu 12).
You can overload the ^ operator, but that only lets you define what it means for a new data type. You can't change what an existing operator means for one of the built-in data types such as integers.
