Convert String to char[i]
This likely an easy question but how can I convert a c String to a char[i] array? Most answers I am seeing are for C++, but I am looking for an answer for a c String. For example:
 String latitude = "30.111111";
 char latitudec[10];
I want latitudec to have the same value as latitude here
See toCharArray() - Arduino Reference
Thank you I don't understand what the buffer is though I have tried:
latitude.toCharArray(latitudec, 10);
but this does not compile
Post a full example code like
Of course the real question is why do you need a String in the first place and why you want to duplicate the content in a new buffer.
This is a valid question and I can tell you that you won't like my answer. But I am interested in understanding what I am missing here. That is simply how to convert a c String to a char array
You sure that's the reason it doesn't compile? This compiles fine.
char latitudec[10];
I did not have the char latitudec[10]; portion! Thank you I feel stupid
The link was an example code to check in the simulator
Use the detailed / verbose option of the IDE to get detailed error reporting when compiling
