Problem getting string to convert to char array
Can someone help me to understand how to do this, i tried many many ways but there is always an error when i tried to compile my script
What i'm trying to do is convert a string to a char array, and for some crazy reasons whatever i try it always give me a compile error.
Here what i try to convert string
This is juste a small portion of the string coming from loading a web page containing parameters for different led panel 16x16 as an example
001,16,16,256,000,0
000,#FF0000,000,1,0,0
001,#00FF00,001,0,0,0
002,#0000FF,002,1,0,0
003,#FFFFFF,003,0,0,1
004,#FFFFFF,004,0,0,1
005,#FFFFFF,005,0,0,1
006,#FFFFFF,006,0,0,1
007,#FFFFFF,007,0,0,1
008,#00FF00,008,0,0,0
009,#FFFFFF,009,0,0,1
010,#FFFFFF,010,0,0,1
011,#FFFFFF,011,0,0,1
012,#FFFFFF,012,0,0,1
This is an US-ASCII file encoded
NOTE I don't have a choice to use STRING since the function return a String object
Here is my sample code
// note the payload string come from httpGet from httpClient lib
void setPanelDataToObject(String payload) {
  /* function to process the panels data into memory of esp32
     the data is contained in payload string and must be parsed
     to the panel and led objects
  // get the first line of panel
  const char *lineSep = "\r\n" ;
  const char *delimiter = "," ;
  char *p ;
  int strlength = 0;
  Serial.println("Result of parsing for each lines") ;
  Serial.println("Should be complete lines with data each") ;
  strlength = payload.length() + 1 ;
  char *myString[strlength] ;
        payload.toCharArray(myString,strlength) ;
       // char *strncpy(myString,payload.c_str(),strlength) ;
        Serial.println("Payload String from panel1.html") ;
        Serial.println(payload) ;
  char *token = strtok(myString,lineSep) ;
  while (token != NULL) {
    Serial.println(token) ;
// this is to get every line separate and later get each parameter of that line
// to be put in an object class that can be used!
    token = strtok(NULL,lineSep) ;
type or paste code here
And this is the error that i get when compiling
MULTI-PANEL-8266-SETUP:295:47: error: no matching function for call to 'String::toCharArray(char* [strlength], int&)'
In file included from C:\Users\jchar\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32/Arduino.h:165,
And if this is not the same error it don't give,it always gives me the non possibility to convert to Char array by using other method like strncpy in c String class etc.
This normally will take me a week or 2 to finish my code in other language that i use currently.
I must say that i never programmed in C++ or in adruino but i know how to program stuff i know my way around in other language.
The only thing that should be simple enought already take me 2 month to understand (to some extend) the C++ language and mosthly it's illarious syntax that supposedly to be simple in Adruino.
I programs other stuff in Adruino but here i hit a wall, cause i don't know what i'm doing wrong, i follow many samples in the forum but i'm stuck here, maybe i'm doing something wrong i don't know and i'm on the verge of abandonning this project that took me way too much time.
So PLEASE if someone knows a way to fix this i would really really appreciate the inlightning of this code.
Thanks all and Happy programming
So, your first problem is your code doesn't have a setup() or loop(). Not sure how you got this far without those.
Sorry, no, actually, your first problem is you posted in a category where posting is expressly forbidden. Suggest you request that a moderator move your topic to, maybe,
Not this:
But:
char myString[strlength] ;
The difference is the *
Do not post in "Uncategorized:; see the sticky topics in Uncategorized - Arduino Forum
Topic moved.
you should post your complete sketch. There is a very high chance that what you "load from a webpage" will be already a so called c_string which is an array of char.
To clear this you should post your complete sketch from the very first line to the very last line.
A posting can hold 120.000 characters which equals to around 3000 lines of code. Each line containing 40 characters.
You can have waiting because some user do not guess around
until some users that might guess post some guessings which will take more time because
you have to check all guessings
or straight forward posting your complete sketch for a straight forward decent analyse
