Converting a piece of PIC code to Arduino
Hello there,
I found a piece of code in PIC language that I've tried to convert in arduino.
#include <xc.h>
#include <htc.h>
#pragma config BOREN = OFF, CPD = OFF, FOSC = INTRCIO, MCLRE = OFF, WDTE = OFF, CP = OFF, PWRTE = OFF
#define FOSC 4
extern void eeprom_write(unsigned char addr, unsigned char value);
extern unsigned char eeprom_read(unsigned char addr);
void delay_ms(unsigned int duration);
void main(){
        unsigned char val_GPIO;
        unsigned char eeprom_id;
        unsigned char counter_type;
	GPIO = 0; //init & hold reset low
	TRISIO = 0x8; //b001000 hold reset #GP2 as output
   	eeprom_id = eeprom_read(0x00); //read eeprom value
        counter_type = 3; //default 2/4 games
        if(GP3==1) counter_type = 2; //GP3 == VCC
        if(eeprom_id >= counter_type){
            eeprom_id = 0; //init eeprom value if empty/new
            }else{
            eeprom_id++;
    eeprom_write(0x00, eeprom_id);
    delay_ms(30);
    //GP0 = bankswitch EPROM
    //GP1 = bankswitch EPROM #2
    //GP2 = /RST
    //GP3 = - switch between 2/4 and 3 games config
    //GP4 = SRAM 1
    //GP5 = SRAM 2
     switch(eeprom_id){
       case 0:
       //000000
       val_GPIO = 0x0;
       case 1:
       //010001
       val_GPIO = 0x11;
       case 2:
       //100010
       val_GPIO = 0x22;
       case 3:
       //110011
       val_GPIO = 0x33;
    TRISIO = 0xC; //in GP2 & GP3
    GPIO = val_GPIO; //high-low
   while(1){
    //endless loop
void delay_ms(unsigned int duration){
    // delay in miliseconds for 4.0MHZ crystal
    unsigned int i;
    for(;duration!=0;duration--){
        for(i=0;i<=50;i++){
            asm("nop");
            asm("nop");
            asm("nop");
        asm("nop");
        asm("nop");
Here is what I've tried :
#include <EEPROM.h>
int GP3 = 13;
int GP2 = 12;
pinMode(GP2,LOW);
counter_type = 3;
eeprom_id = EEPROM.read(0x00);
if(GP3==1) {
counter_type = 2;
if (eeprom_id >= counter_type) {
  eeprom_id = 0;
}else{
  eeprom_id++;
EEPROM.write(0x00, eeprom_id);
delay(30);
switch(eeprom_id){
      case 0:
       //000000
       val_GPIO = 0x0;
       case 1:
       //010001
       val_GPIO = 0x11;
       case 2:
       //100010
       val_GPIO = 0x22;
       case 3:
       //110011
       val_GPIO = 0x33;
//IM BLOCKED HERE
I didn't manage to end the code, if anyone knows if it's correct and can end the code that would be generous.
Thanks by advance
Regards
You never actually stated what you expect the code to do.
Or do we have to guess?
Thanks for your reply, sorry i forgot to mention it :
It's meant to bankswitch an eeprom.
The pic code is for a PIC12F629.
//IM BLOCKED HERE
Well, this part will certainly work for both the PIC and the Arduino:
  while(1){
    //endless loop
This part sets pins GP2 and GP3 as input, and sets the data bits in val_GPIO to the output pins.
Great, thanks for your help.
How could I do that ?
Thanks again
Use digitalWrite(), or direct port access. It depends on your wiring, which you also forgot to post.
PS: SRAM1 and SRAM2 is for bankswitching the ram, it's in option.
jremington:
If GP2 & GP3 are set as input then what are the other outputs because they aren't set.
What i did :
pinMode(GP2, INPUT);
pinMode(GP3, INPUT);
digitalWrite(?????? , val_GPIO);
Thanks
Do you actually understand what the PIC is doing?
As far as inputs and outputs are concerned, perhaps you should go back and review how to blink an LED and read a switch on the Arduino. The same principles apply to this project.
Not really.
The other pins of the PIC aren't set as output so how could It write then.
It would be like this to set the data_bits to the outputs ?
digitalWrite(GP0 , val_GPIO);
digitalWrite(GP1 , val_GPIO);
digitalWrite(GP4 , val_GPIO);
digitalWrite(GP5 , val_GPIO);
If you want to duplicate the operation of the PIC, it is absolutely essential to first understand what that program is doing, which is to set certain pins to certain values.
Consult the 12F679 data sheet, section 3.1, to learn about the function of the TRISIO register and how that sets up input and output pins.
Thanks,
I understand know but to be sure I got a question :
//010001
       val_GPIO = 0x11;
This code means that GP1 and GP5 will be "high" ?
But what about this ?
It says that it hold reset low but =0 seems to be all pins.
Thanks
Regards
No. Pins GP0 and GP4 will be high, if val_GPIO is output to the port.
It says init & reset. In fact all OUTPUT pins will be set low.
Thanks.
This is what i've done. I didn't define the other pins as OUTPUT since there isn't in the pic code, should i ?
#include <EEPROM.h>
int GP5 = 13;
int GP4 = 12;
int GP3 = 11;
int GP2 = 10;
int GP1 = 9;
int GP0 = 8;
  pinMode(GP2,OUTPUT);
  counter_type = 3;
  if(GP3==1) {
    counter_type = 2;
    eeprom_id = 0;
  else{
    eeprom_id++;
  delay(30);
  switch(eeprom_id){
  case 0:
    //000000
    //val_GPIO = 0x0;
    digitalWrite(GP0, LOW);
    digitalWrite(GP1, LOW);
    digitalWrite(GP2, LOW);
    digitalWrite(GP3, LOW);
    digitalWrite(GP4, LOW);
    digitalWrite(GP5, LOW);
  case 1:
    //010001
  //  val_GPIO = 0x11; // GP0 & GP4 = HIGH
    digitalWrite(GP0, HIGH);
    digitalWrite(GP4, HIGH);
  case 2:
    //100010
   // val_GPIO = 0x22;
    digitalWrite(GP1, HIGH);
    digitalWrite(GP5, HIGH);
  case 3:
    //110011
//    val_GPIO = 0x33;
In Arduino, all pins that are to be used for output must be declared OUTPUT.
The point is not to duplicate the PIC code, it is to make the ATMega processor act exactly like the PIC processor in the application.
To do that, you have to know exactly what the PIC is doing, and follow all the Arduino language rules to make the ATMega processor do exactly the same thing.
Why are you doing this? Why not just use a PIC?
jremington:
Good question.
We await the answer with great interest ....................
I don't have one and I wanted to know how the code would be for an Arduino.
I got some attiny's so I wanted to use one of them.
