I'm currently doing a project to convert an analog ammeter using moving coil for indicator to digital.
The deflection of the needle is depending on the current output that is wired to the meter.
For the needle to fully turn, it requires about 2mA of current. [I tested it by inputting 2mA of current through it externally.]
But when I tested it out while the machine is running at maximum capacity, the current output that is wired to the ammeter is measured at about 40mA.
Any idea why is it like this?
Besides, since Arduino can only takes 0-5V as analog signal. So I try to convert the 40mA to 5V signal by using this approach. Following was my converter circuit diagram:-
|---[125 Ohm]---| V=IR
| | R=125 Ohm
|[40mA]|
I connect the + to A0 and - to GND of my Arduino, but somehow this approve doesn't work and fried my resistor and resistors.
Any idea what approach can I use other than this?
Thank you.
