Lets say I want to know how many mA per hour my supercapacitor can supply and assuming my capacitor is rated 2.7V and has 2F:
Farad = (Ampere per second) / Volt
Farad * Volt = Ampere per second
so
2F * 2.7V = 5.4 Ampere per second
5.4 Ampere per second = 0.0015 ampere per hour //dividing it by 3600
0.0015Ah = 1.5mAh
edit: this part is wrong
but. this assumes constant voltage. Actually there is a linear drop in voltage until the capacitor reaches zero. So the actual energy it can provide is 1.5mAh/2
Answer: A capacitor with 2F and 2.7 volt can supply 0.75mAh (asuming I can somehow use all the energy to the last bit.) * Is this correct?
A bit complicated. A 2F 2.7V capacitor can store Q=CV=5.4 Coulombs of charge. Now 1 mAh is 0.001 Columbs per second (0.001A) multiplied by 3600 seconds or 3.6 Coulombs. So I think the capacitor is equivalent to 5.4/3.6 = 1.5mAh.
Of course, the capacitor voltage is going to go down linearly towards 0V, not like a battery, if you draw a steady 1.5mA from it for 1 hour.
The Basic Motor Driver: simple, inexpensive motor driver for 1 stepper motor or 2 DC motors
yeah. that's basically my reasoning. however: does the 1.5mAh already take the linear decrease of voltage into account? i.e. at 50% discharge the voltage has dropped to 1.35V, changing the formula we used to calculate those 1.5mAh.
Cause its a linear drop, can we simply divide the 1.5mAh by 2, in order to get the actual available energy? (think of it as a graph. voltage is X and time is Y. the area underneath the voltage is double the size as it would be if it would decrease in a linear manner.)
But somehow that seems both too complicated and too simple at the same time.
so. back to my original question. does 1.5 already take the voltage drop into account?
Both mAh and Coulombs are measures of charge (hence energy) storage. There is no consideration of voltage, just a measure of how much energy the capacitor can store when fully charged. It doesn't matter how the voltage varies from 2.7V to 0, linear, non-linear, etc.
Think about a 5.4L tank of water. The capacity is 5.4L. If you drain it at 1.5mL per second, it will take 1 hour to fully drain it. Or you can drain it at 3mL per second for half an hour. Or start, stop, start, stop, etc. It doesn't matter -- the capacity of the tank is 5.4L.
Same for the capacitor. The capacity is 5.4 Coulombs of charge. If you drain it at 1.5mA it will take 1 hour to fully drain -- hence you can say it's equivalent to 1.5mAh of capacity. Any other way you do it (3mA, linear, non-linear, etc.) does not change how much charge (hence energy) the capacitor can store.
The QuadRAM shield: add 512 kilobytes of external RAM to your Arduino Mega/Mega2560
Also you cannot blithely assume an ultra capacitor is a linear device as its about as far from an ideal parallel-plate capacitor as its possible to get!
Yes, MarkT, you are right. Grumpy Mike already pointed that out.
I was just told that 4 of the capacitors I described at start (so 2.7V & 2F) In parallel would be equal to 75mAh. This information comes from the manufacturer.
Does anyone have any idea how they arrive at that conclusion?
fkeel:
They multiplied by 3.6 instead of dividing by 3.6 - and didn't check their calculations (marketing department then!)
thanks @rugged circuit. I was really confused, as during my research I taught myself that it is both constant and exponential... now it makes sense.
I will ask them how they got that number. I just wanted to check with you guys first, as I did not want to call them on a mistake which was on my side...
p.
edit: they just corrected themselves, saying its 6mAh
