Hi There,
Recently learning more about Arduinos, and have been practicing mainly using TinkerCAD, and have pretty complex code written for a Puzzle Box project I've been working on. I have the code running in TinkerCAD, but if I simply transfer this into the Arduino IDE will it run, or is it not as straightforward as this? Thanks
Hi!
I took this chunk, googled and found several hits:
Your welcome, and welcome! to the forum ![]()
Are you able to copy and paste code from TinkrCad to Arduino IDE?
Also, you can download the code and open up in a normal text editor
When moving code from Tinkercad to the Arduino IDE, be aware that Tinkercad simulations often simplify hardware interactions. You might need to adjust pin configurations, libraries, and hardware settings for the actual environment. Double-check your code for any necessary tweaks to ensure compatibility.
