Hello,
I am trying to convert multi byte serial ASCII data into an integer.
At the moment I am storing my a received ASCII serial data into INT so for example: -
int received[4]
received[0] = 48
received[1] = 50
received[2] = 48
received[3] = 48
received[4] = 48
This converts to from ASCII to 04000.
I would like to convert this into 4000 and store into an integer of it's own. For Example: -
int convertedNumber = 4000;
I have tried a couple of methods - toInt() & atol() and String to Int conversions but so far I have been unsuccessful.
Could anyone give me any pointers? (No pun intended ;-))
Thanks in advance.
If you use a char array rather than an int array, then you can easily use the provided atoi function.
int received[4]
received[0] = 48
received[1] = 50
received[2] = 48
received[3] = 48
received[4] = 48
A four element array doesn't have an element with the index four.
Perhaps that's part of your problem
it should be like this:
char received[6];
received[0] = 48;
received[1] = 50;
received[2] = 48;
received[3] = 48;
received[4] = 48;
received[5] = '\0';
int value = atoi(received);
arduino_new:
char received[6];
received[0] = 48;
received[1] = 50;
received[2] = 48;
received[3] = 48;
received[4] = 48;
received[5] = '\0';
Great works well - Thanks
