Hi all
Maybe a small question for Arduino programmers but for me, 'grandpa jaap', difficult
For an application I want the absolute max value know for a small scale unit.
I use the LCD ( LCDi2c )
I quote the LCD.print (Scale.get_units) ; call and try to copy this value to a variable called "value Copy'.
Value copy is assigned as Float and presets with 0. … there are no errors ..
The returned value of lcd.print (Scale.get_units(), 4 ); is show on the LCD and is OK.
It Returnes
My problem is how to copy the float value of ‘get_units’ to an variable, (Value _copy)
As I used ( value_copy) = ( get_units ); returned Value_copy is always 0.000 So wich value and where is the real value
Also tried without ( ) .
As I say, I was over 40 years an Microchip asm programmer, Now ( try ) learning the C++ language..
I must take a copy to calculate the max presure value ( value on display on the beneath ‘max druk’ ) but wich value do I need and how can I copy this ‘get_units value’??
Met vriendelijke groet, Kind regards, Mit freundlichen Grüßen,
"Grandpa jaap"
