Posting pictures of code is a waste of time and you don't even say what the problem is
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
Semicolons do not belong at the end of an "if" like you have
But yeah, post text, not pictures; we are not Ancient Egyptians
Although I also hate screenshots of code and errors, the error message gives you a hint. Did you read the error message or just dump the screenshot here without looking at it?
This is the cording.. the error in if(cm<50)
pinMode(buzzer,OUTPUT);
//measure the ping time in cm
cm = 0.01723 * readUltrasonicDistance(7, 7);
//convert to inches by dividing by 2.54
inches = (cm / 2.54);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.printIn("cm");
delay(100); //Wait for 100 millisecond(s)
if (cm<50);
digitalWrite(buzzer,HIGH);
digitalWrite(buzzer,LOW);
I see that you decide to ignore the advice about using code tags when posting code and that you also did not post the complete sketch or full error message
There is a semicolon here that should be removed:
if (cm<50);
See reply #3, from 2 hours ago ![]()
If that's your complete code, there is no surprise. To begin with, you have no variables or constants with global scope. There is also no function readUltrasonicDistance defined in your code.
The full list of errors and warnings
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_115289\sketch_may19a.ino: In function 'void setup()':
sketch_may19a:4: error: 'buzzer' was not declared in this scope
pinMode(buzzer, OUTPUT);
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_115289\sketch_may19a.ino: In function 'void loop()':
sketch_may19a:10: error: 'cm' was not declared in this scope
sketch_may19a:10: error: 'readUltrasonicDistance' was not declared in this scope
sketch_may19a:12: error: 'inches' was not declared in this scope
sketch_may19a:16: error: 'class HardwareSerial' has no member named 'printIn'; did you mean 'println'?
println
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_115289\sketch_may19a.ino:19:15: warning: suggest braces around empty body in an 'if' statement [-Wempty-body]
if (cm < 50);
sketch_may19a:21: error: 'buzzer' was not declared in this scope
digitalWrite(buzzer, HIGH);
exit status 1
option enabled in File -> Preferences.
So how i fix this?
Have you posted the complete sketch that you are trying to compile ?
Maybe you could point us at the site you got the sketch from
Did you type in all of the code that was shown on the screen ? If so, then you have not posted it here
Yes i type all the code but I don't know why still error at if(cm<50)
Then why haven't you posted all of your code ?
Just want confirmation
Confirmation of what ?
This all code
Just help me to fix thi error at if(cm<50)
#define buzzer 10
int inches = 0;
int cm = 0;
long readUltrasonicDistance (int triggerPin, int echoPin)
pinMode (triggerPin, OUTPUT) ; //Clear the trigger
// Sets the trigger pin to HIGH state for 10microseconds
digitalWrite (triggerPin, High);
delayMicroseconds(10);
digitalWrite (triggerPin, LOW);
pinMode (echoPin, HIGH);
// Reads the echo pin, and returns the sound wave travel time in microseconds
return pulseIn(echoPin, HIGH);
Serial.print (inches);
Serial.print ("in, ");
Serial.print (cm);
if(cm<50)
should be
digitalWrite (triggerPin, HIGH);
should be
Serial.println("cm"); //letter l for (line) not I for (India)
With those changes the code compiles
