Correct microprocessor to replace Arduino Uno
Hello everyone,
I have a working project on my Arduino Uno to control an RGB-LED (or -Strip) and want to move it onto a circuit board. In this process I also want to replace the Arduino with a dedicated microprocessor.
What would be the most efficient option to do this? (apart from just a ATmega328P)
Some specs of the project to be migrated (according to the console of the Arduino IDE):
  • Project requires 4 analog pinouts
  • Sketch uses 10,600 bytes
  • Global variables use 490 bytes
  • Code uses the IRRemote library
  • makes heavy use of the millis() function
I have found this library for the ATtiny, the ATtiny85 version of which would, to my understanding, have just enough RAM.
Would the ATtiny85 work? Other suggestions? Thanks!
Can you re-phrase that? Uno has zero analog outputs...
You require one digital output to drive your strip. Don't know what else you need yet.
Maybe you could consider attiny84. It's almost the same as attiny85 but with more pins. You would need to reduce the compiled sketch size to below 8192 bytes for either '85 or '84. That might not be impossible. Post your code. We might spot some ways to shrink it. Also you could try switching on Link Time Optimisation (LTO).
There are other ways to move to a circuit board while still using the same chip. Nano 3 and Pro Mini both use the same chip as Uno. Or you can use a bare atmega328 chip. If 8MHz is fast enough (which is true for almost all projects) then you may not need a crystal+caps.
Why are you against using an ATmega328P ?
You have code that runs on it. It has all the inputs, outputs and memory that you need
If size is a problem then you could use an Arduino Micro or Nano in place of the Uno
If it just has enough ram (512 bytes?), it might very well not have enough ram. You will need to count local variables and stack usage as well for total memory usage.
What is an 'analog pinout'?
The tiny85 doesn't sound like it has enough program memory.
It would fit in an atmega168, or probably an attiny1634, but there isn't much of a reason for the change. In quantity, you'd save a few cents per chip, maybe.
You can put a 328 on a board that only breaks out some of the pins, and it gets significantly smaller. Adafruit trinket pro comes to mind.
Thanks everybody for your tips, I'll just try to refactor my code a bit and port it onto an ATmega328P.
@PaulRB, @INTP: Oops, I mean pinouts with PWM of couse. :sweat_smile:
