I was able to light up the LED when I wired a power supply to the circuit correctly, I am unsure of if the capacitor was working correctly though as when i turned the supply off the LED seemed to dim at the same rate as when the capacitor was not there
I made a hand crank to turn the motor, I even tried spinning it with a drill with one or more of the wires attached and still nothing
Did the motor run correctly before you decided to make it into a generator? Did you test the wire leads for continuity before you tried to make a generator? Did you check the wires for resistance between them using your Ohmmeter and reverse the connections to see if there is a diode inside the motor?
Yes. Since you did not test the motor, we can assume your BLDC motor has internal electronics that make the motor turn. The only BLDC motor that will do what you want is the type with an external speed control.
I checked the resistance, there was a reading on each pair, each one different.
I also checked the output AC voltage of the motor on a Multimeter, the highest value i was able to get was 0.2 V. i can understand that this is most likely not enough for the LED to light up even with the capacitor. So my initial thoughts is that i need to increase the RPM.
What do you mean by "different"? The windings should all have the same resistance, within a few percent. Report the actual resistance reading for each.
why is a regular DC motor able to produce a flash on the LED
Because it is working as expected. Your setup may not be.
DC motor current travels in one direction so the forward-biased LED will light until the charge is gone at the speed of light of the collapsing field.
Three-phase AC from the BLDC travels in alternating directions half the time, so without rectification and a storage device, the LED across one phase is wired wrong 5/6 of the time. The "good" 1/5 is dissipated in speed of light, reversing polarity, and time to forward-bias the LED.
Sorry, that doesn't make much sense. I suggest to find another, known working BLDC motor with no internal driver (just three leads) for your experiments.
Incidentally, a permanent magnet stepper motor (the most common type) has the same internal structure, but only two coils. It will also work as a generator.
That motor has a 13 turn winding with resistance of 0.09 Ohms, which explains your low resistance readings with the multimeter. The "1000kV" rating means you that if you spin the shaft at 1000 RPM you get just 1 Volt (AC) out of it, not enough to light an LED, so it would be a very poor choice for a generator.
