Could not find a valid MPU6050 sensor, check wiring!
Hello,
I have arduino nano + MPU6050 (GY-521) - works fine with other libraries for this sensor. But I would like to find why I get this error with this library.
Initialize MPU6050
I followed this tutorial.
I tried to swap SCL and SDA wires - not helped, connected back how described in tutorial.
I searched information related to wires/pins in MPU6050.h and MPU6050.cpp - nothing found.
The initialisation of mpu object fails. How can I get more details in console to identify the root of the problem?
Nano, or Nano Every?
Nano
At a pinch, have you got 4k7 pullups on the SDA and SCL lines?
Tom... :slight_smile:
I don't have any resistors on SDA, SCL lines, as this is not required in the tutorial.
I opened MPU6050.cpp and I see for the communication is used the same Wire.h that works in basic hello world test example (but another library).
#include <Wire.h>
#include <math.h>
#include <MPU6050.h>
bool MPU6050::begin(mpu6050_dps_t scale, mpu6050_range_t range, int mpua)
    // Set Address
    mpuAddress = mpua;
    Wire.begin();
If wire.h is OK and arduino nano can talk to mpu6050, then the problem is only in this library mentioned above. I tried to look in MPU6050.h the registers addresses and compared them to the rigister addresses from mpu6050 datasheet and they are correct.
MPU address is correct - 0x68 because I don't use AD0 pin.
I MPU6050.cpp, begin function contains 3 parameters, mpu6050_dps_t scale, mpu6050_range_t range, int mpua, but in the arduino sketch, I see only 2 parameters in begin: mpu6050_dps_t scale, mpu6050_range_t range.
Should I add the address in the sketch begin too?
cpp
sketch
while(!mpu.begin(MPU6050_SCALE_2000DPS, MPU6050_RANGE_2G))
Not helped declaring the address in begin. It's predeclared in mpu6050.h
The problem in somewhere else...
run an I2C scan to see if anything is detected
Here the results:
Arduino MultiSpeed I2C Scanner - 0.1.11
1 devices found in 4375 milliseconds.
TIME DEC HEX 50 100 150 200 250 300 350 400 [KHz]
30525 104 0x68 V V V V V V V V
0x68 is a correct address for a MPU6050 (The device has two valid addresses, 0x68 or 0x69, depending on the status of the AD0 pin) so that's good news - it seems to be visible
(on a Nano SDA -> A4; SCL -> A5 should be the correct wiring)
you would not be the first one with crappy build quality on such devices...
Have you at least tried the 4K7 pullup resistors?
J-M-L:
I confirm, SDA -> A4; SCL -> A5
This is not a case for crappy build because the sensor is detected by I2Cscanner and other libraryes work fine with this sensor. It's not a hardware problem, I think, but a software problem. I need bigger debug level in console to see more details, because this code reports only "check wiring". I checked - wiring is OK.
could be seen but may be not respond to targeted commands.
what do you mean ? Do you have a library working fine with your device? why don't you use it?
TomGeorge:
Yes, I tried. Not helped.
Because this library can be used for a very good motion detector. Read my first post.
Other libraries works, but I need to add a lot of C++ code to adjust for a good motion detector. I'm new in C++ and it's difficult for me to start from zero.
While debugging this code I'm learning.
I found the problem by myself. Now I don't get anymore "check wiring" in the console.
Initialize MPU6050
 * Sleep Mode:            Enabled
 * Clock Source:          Internal 8MHz oscillator
 * Accelerometer:         +/- 2 g
 * Accelerometer offsets: 2304 / 2800 / 1021
 Xraw = 0.00 Yraw = 0.00 Zraw = 0.00
 Xnorm = 0.00 Ynorm = 0.00 Znorm = 0.00
I just modified the function "Check MPU6050 Who Am I Register" to return always true, and the code runs. Now I'm checking why it can't read who am I register.
I'm trying to figure out how to read bits from registers and compare to datasheet. For example WHO_AM_I register.
Register adress is defined:
#define MPU6050_REG_WHO_AM_I (0x75) // Who Am I
The default value of this register is 0x68
here I modified to return true, but in reality it returns false:
if (fastRegister8(MPU6050_REG_WHO_AM_I) != 0x68)
Something is wrong in reading function?
So I decided to see what's inside WHO_AM_I register with this simply code:
uint8_t whoami_bits;
	Wire.beginTransmission(0b1101000); // the mpu address in binary or 0x68 in hex
	Wire.write(0x75);                             // select register 0x75 REG_WHO_AM_I
	Wire.endTransmission();
	Wire.requestFrom(0b1101000,6);      // request for 6 bits from selected register
	while (Wire.available() < 6);
	whoami_bits = Wire.read();
	Serial.println("Who_AM_I register contents :");
	Serial.println(whoami_bits);               // displaying contents
In the console I get:
Initialize MPU6050
152
What is 152 ?? Decimal 152 is 0x98 in hex. Wrong value. Or I'm interpreting something wrong here.
Can someone give an idea? I am reading correctly the values?
The second argument to requestFrom() is the number of BYTES being requested, not bits.
OK. 6 bytes not bits. You can ignore my typo in the comment. This does not affect the result. I've requested even 1 byte and I get the same result 152 (0x98), but the right result should be 104 or 0x68
To read that register you need to do
uint8_t value;
Wire.beginTransmission(0x68);
Wire.write(0x75);
Wire.requestFrom(0x68, 1);
value = Wire.read();
// now print it
Serial.print(value, BIN);
Then the spec states WHO_AM_I[6:1] that means you need to only take bits 1 to 6 of that register read to form the address and describes it this way
This register is used to verify the identity of the device. The contents of WHO_AM_I are the upper 6 bits of the MPU-60X0’s 7-bit I2C address. The least significant bit of the MPU-60X0’s I2C address is determined by the value of the AD0 pin. The value of the AD0 pin is not reflected in this register .
The I2C bus specification specifies that in standard-mode I2C, the slave address is 7-bits long followed by the read/write bit.
The default value of the register should be 0x68
