I tryed this, but didnt worked:
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the Serial Monitor.
Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
int sensorValue1 = digitalRead(11);
int sensorValue2 = digitalRead(12);
Serial.println(sensorValue+sensorValue1+sensorValue2);
delay(1); // delay in between reads for stability
What can I do?
Btw, do u remind my other forums chat, someone eraased my forums chat....
Or well, could remind were they were, thank you anyways.
