Here is what i ve done so far...
As you can see is a code which combines a real time clock with a ds1307 RTC module and a coutdown Timer which is set it up from the user through the serial monitor.
It works fine in my serial monitor as you can see in the attached fotos below but it doesnt in my P10 led Module.
At my P10 DMD led module only the Time looks ok. The countdown appears as symbols,letters etc
Any help ???
#include <Wire.h>
#include "RTClib.h"
#include <SPI.h> //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise)
#include <DMD.h> //
#include <TimerOne.h> //
#include "SystemFont5x7.h"
#define HC12 Serial
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
RTC_DS1307 rtc;
void ScanDMD()
dmd.scanDisplayBySPI();
unsigned long Watch, _micro, time = micros();
unsigned int Clock = 0, R_clock;
boolean Reset = false, Stop = false, Paused = false;
volatile boolean timeFlag = false;
int i;
int s;
String str = "";
char stringa[10];
Timer1.initialize( 3000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
Timer1.attachInterrupt(ScanDMD); //attach the Timer1 inte
//dmd.clearScreen(true ); //true is normal (all pixels off), false is negative (all pixels on)
dmd.selectFont(SystemFont5x7);
while (!Serial); // for Leonardo/Micro/Zero
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// FEBRUARY 2, 2019 at 5am you would call:
rtc.adjust(DateTime(2019, 3, 3, 2, 40, 0));
HC12.begin(9600);
Stop = true;
if (HC12.available() > 0) {
int inbyte = HC12.read();
switch (inbyte) {
case 'a' : // SET TIMER IN SECONDS
memset(stringa, 0, sizeof(stringa)); // set string contents to zero
i = HC12.readBytesUntil('\n', stringa, sizeof(stringa)-1); // Read line of input
String sec(stringa);
i=sec.toInt();
SetTimer(0,0,i);
StartTimer();
case 'r' : // Reset timer
Reset =true;
CountDownTimer(); // run the timer
// this prevents the time from being constantly shown.
if (TimeHasChanged() )
Serial.print(ShowHours());
Serial.print(":");
if (((Clock / 60) % 60)<10) {
Serial.print("0");
Serial.print(ShowMinutes());
dmd.drawString( 0, 0, minutes , strlen(minutes()), GRAPHICS_NORMAL );
else {
//dmd.drawString( 0, 0, minutes , strlen(minutes()), GRAPHICS_NORMAL );
// Serial.print(ShowMinutes());
Serial.print(":");
if (Clock % 60<10) {
Serial.print("0");
Serial.println(ShowSeconds());
//dmd.drawString( 10, 0, bar , strlen(bar), GRAPHICS_NORMAL );
else {
dmd.drawString( 10, 0, ShowSeconds() , strlen(3), GRAPHICS_NORMAL );
DateTime now = rtc.now();
DateTime future (now + TimeSpan(0,8,2,6)); //
Serial.print(future.hour(), DEC);
Serial.print(':');
Serial.print(future.minute(), DEC);
Serial.print(':');
Serial.print(future.second(), DEC);
dmd.drawString( 13, 8, ":",1, GRAPHICS_NORMAL );
char h [3];
String str1;
str1=String(future.hour());
str1.toCharArray(h,3);
dmd.drawString( 0, 8, h , strlen(h), GRAPHICS_NORMAL );
char m [3];
String str2;
str2=String(future.minute());
str2.toCharArray(m,3);
dmd.drawString( 19, 8, m , strlen(m), GRAPHICS_NORMAL );
boolean CountDownTimer()
static unsigned long duration = 1000000; // 1 second
timeFlag = false;
if (!Stop && !Paused) // if not Stopped or Paused, run timer
// check the time difference and see if 1 second has elapsed
if ((_micro = micros()) - time > duration )
Clock--;
timeFlag = true;
if (Clock == 0) // check to see if the clock is 0
Stop = true; // If so, stop the timer
// check to see if micros() has rolled over, if not,
// then increment "time" by duration
_micro < time ? time = _micro : time += duration;
return !Stop; // return the state of the timer
void ResetTimer()
SetTimer(R_clock);
Stop = false;
void StartTimer()
Watch = micros(); // get the initial microseconds at the start of the timer
time = micros(); // hwd added so timer will reset if stopped and then started
Stop = false;
Paused = false;
void StopTimer()
Stop = true;
void StopTimerAt(unsigned int hours, unsigned int minutes, unsigned int seconds)
if (TimeCheck(hours, minutes, seconds) )
Stop = true;
void PauseTimer()
Paused = true;
void ResumeTimer() // You can resume the timer if you ever stop it.
Paused = false;
void SetTimer(unsigned int hours, unsigned int minutes, unsigned int seconds)
// This handles invalid time overflow ie 1(H), 0(M), 120(S) -> 1, 2, 0
unsigned int _S = (seconds / 60), _M = (minutes / 60);
if(_S) minutes += _S;
if(_M) hours += _M;
Clock = (hours * 3600) + (minutes * 60) + (seconds % 60);
R_clock = Clock;
Stop = false;
void SetTimer(unsigned int seconds)
// StartTimer(seconds / 3600, (seconds / 3600) / 60, seconds % 60);
Clock = seconds;
R_clock = Clock;
Stop = false;
int ShowHours()
return Clock / 3600;
int ShowMinutes()
return (Clock / 60) % 60;
int ShowSeconds()
return Clock % 60;
unsigned long ShowMilliSeconds()
return (_micro - Watch)/ 1000.0;
unsigned long ShowMicroSeconds()
return _micro - Watch;
boolean TimeHasChanged()
return timeFlag;
// output true if timer equals requested time
boolean TimeCheck(unsigned int hours, unsigned int minutes, unsigned int seconds)
return (hours == ShowHours() && minutes == ShowMinutes() && seconds == ShowSeconds());
