it wont turn the buzzer off or respond when the buzzer is on
int seconds = 20;
int buzzer = 12;
int btncount;
int btn = 2 ;
pinMode(buzzer, OUTPUT);
if (digitalRead( btn ) == LOW) //check if button is pressed
++ btncount; // if pressed add one to variable btncount
delay(200);
if (btncount == 1){
Serial.println(seconds);
seconds -= 1;
while (seconds <=-1 && seconds >= -10){
digitalWrite(buzzer, HIGH);
delay(2);
digitalWrite(buzzer, LOW);
delay(2);
if (digitalRead( btn ) == LOW){
++ btncount;
if (btncount > 1){
btncount=0;
seconds == 20;
Serial.println("reset");
It would help if you describe what the code is supposed to do.
Observations:
You didn't configure btn as an input in setup() . I would suggest:
pinMode(btn, INPUT_PULLUP);
You never modify seconds in this while loop. If you ever enter the loop you will stay in it forever!
while (seconds <= -1 && seconds >= -10) {
delay(2);
delay(2);
How is your button wired?
red_c_c_c_p2002:
seconds == 20;
What is the intent of this line of code? '=' is assignment, '==' is comparison.
thanks for the quick reply the code starts at 20 seconds counts down fine, when reaches -1 the buzzer goes off. im trying to then reset it when the buzzers on
And:
delay(200);
if (btncount == 1) {
seconds -= 1;
delay(2);
delay(2);
if (digitalRead( btn ) == LOW) {
++ btncount;
if (btncount > 1) {
btncount = 0;
seconds = 20;
the button is wired to digital pin 2 then + and ground
Let me see if I have this correct:
When the Arduino starts the buzzer is on for 20 secs. When the buzzer goes off then press the buzzer to turn on the buzzer for 20 seconds again.
yeah or to just stop the buzzer period
this is perfect thanks so much!!
1 last thing how would i make it pause resume mid way?
Here is a better way without using delays. You can turn the LED on and off at any time:
const int btn = 2;
const int buzzer = 12;
const unsigned long buzzerOnTime = 20000;
void setup(void)
static unsigned long prevMillis = millis();
static int lastBtnState = digitalRead(btn);
int btnState = digitalRead(btn);
long currentMillis = millis();
if (btnState != lastBtnState)
delay(50); // debounce
lastBtnState = btnState;
if (btnState == LOW)
// If buzzer is on turn it off. If buzzer is off then turn it on.
digitalWrite(buzzer, !digitalRead(buzzer));
prevMillis = currentMillis;
if (digitalRead(buzzer) == HIGH && currentMillis - prevMillis >= buzzerOnTime)
// If buzzer has been on for 20 seconds then turn it off
ToddL1962:
const int btn = 2;
void setup(void)
thanks man this is great i like the logic gonna save it to my buzzer doc for the future ;D
system
Closed
January 22, 2023, 3:27pm
14
