I'm having some newb problems here. Part of my program needs to increment a counter between 1 and 5. I have an up and a down button that will control the incriminating.
My problem is that I cannot get this to work right. I tried using the constrain() command but that skips numbers. For example,
speedCounter = constrain(speedCounter,1,5);
gives me this result. Up button = 2345 Down button = 5321
Or if I use this code below, I get 6,5,4,3,2,1,0,-1. I just want to count from 1 to 5 and stop. Then 5 to 1 and stop.
if((speedCounter >= 5))
speedCounter = 5;
if((speedCounter <= 1))
speedCounter = 1;
speedUpState = digitalRead(speedUp); //Increment the Speed up Button
// compare the buttonState to its previous state
if (speedUpState != lastSpeedUpState)
// if the state has changed, increment the counter
if (speedUpState == LOW)
// if the current state is HIGH then the button
// wend from off to on:
speedCounter++;
lcd.setCursor(13,0);
lcd.print(speedCounter);
EEPROM.update(speedAddress, speedCounter);
else {
// Delay a little bit to avoid bouncing
delay(20);
lastSpeedUpState = speedUpState;
speedDownState = digitalRead(speedDown); //Increment the Speed up Button
if (speedDownState != lastSpeedDownState) {
if (speedDownState == LOW) {
speedCounter--;
else {
delay(20);
// save the current state as the last state,
//for next time through the loop
lastSpeedDownState = speedDownState;
#include <LiquidCrystal.h>
#include <EEPROM.h>
int STEPS = 1600;
Stepper myStepper(STEPS, 9, 8);
long travLength = 0; //Length of traverse
int address = 0;
int Speed = 0;
int Speed1 = 300;
int Speed2 = 400;
int Speed3 = 500;
int Speed4 = 600;
int Speed5 = 700;
int speedUp = 22; //Increase speed button
int speedDown = 23; //Decrease speed button
int travUp = 24; //Increase trav length button
int travDown = 25; //Decrease trav legnth button
int limitSwitch = 50; //limit siwtch for zero position
int enableSwitch = 52; //Trav on/off switch
int travCounter = 0;
int travUpState = 0;
int lastTravUpState = 0;
int travDownState = 0;
int lastTravDownState = 0;
int speedCounter = 0;
int speedUpState = 0;
int lastSpeedUpState = 0;
int speedDownState = 0;
int lastSpeedDownState = 0;
int lengthAddress = 0;
int speedAddress = 0;
byte lengthValue = 0;
byte speedValue = 0;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
pinMode(speedUp, INPUT_PULLUP);
pinMode(speedDown, INPUT_PULLUP);
pinMode(travUp, INPUT_PULLUP);
pinMode(travDown, INPUT_PULLUP);
pinMode(limitSwitch, INPUT_PULLUP);
pinMode(enableSwitch, INPUT_PULLUP);
while (digitalRead(limitSwitch) == HIGH) //Home the traverse arm
myStepper.setSpeed(100);
myStepper.step(-1);
if (digitalRead(limitSwitch) == LOW)
myStepper.step(1000);
lcd.begin(20, 4);
lcd.setCursor(0, 0);
lcd.print("Trav Speed: ");
lcd.setCursor(0, 1);
lcd.print("Trav Length: ");
lcd.setCursor(0, 4);
lcd.print("Status: ");
speedCounter = EEPROM.read(speedAddress);
speedCounter = constrain(speedCounter, 1, 4);
/*if((speedCounter >= 5))
speedCounter = 5;
speedCounter = 1;
speedCounter++;
lcd.setCursor(13, 0);
else {
delay(20);
speedCounter--;
else {
delay(20);
/*speedAddress = speedAddress + 1;
if (speedAddress == EEPROM.length())
speedAddress = 0;
travUpState = digitalRead(travUp);
if (travUpState != lastTravUpState) {
if (travUpState == LOW) {
travCounter = travCounter + 5;
lcd.setCursor(13, 1);
lcd.print(travCounter);
else {
delay(10);
lastTravUpState = travUpState;
travDownState = digitalRead(travDown);
if (travDownState != lastTravDownState) {
if (travDownState == LOW) {
travCounter = travCounter - 5;
else {
delay(10);
if (travCounter > 1000 || travCounter < 0)
(travCounter = 0);
lastTravDownState = travDownState;
lengthAddress = lengthAddress + 1;
// if (lengthAddress == EEPROM.length())
// lengthAddress = 0;
travLength = 3.183 * (travCounter); //3.183 steps/mm : add 20mm for spacing
if (speedCounter == 1)
Speed = Speed1;
if (speedCounter == 2)
Speed = Speed2;
if (speedCounter == 3)
Speed = Speed3;
if (speedCounter == 4)
Speed = Speed4;
if (speedCounter == 5)
Speed = Speed5;
if (digitalRead(enableSwitch) == LOW)
myStepper.setSpeed(Speed);
myStepper.step(13000);
myStepper.step(-13000);
lcd.setCursor(8, 4);
lcd.print("Traverse ON ");
if (digitalRead(enableSwitch) == HIGH)
lcd.print("HOMING ");
myStepper.step(-100);
myStepper.step(0);
lcd.print("Traverse OFF");
I tried a little debouncing and it still didn't help
I suggest you reorganize your code so all the buttons or switches are read in one function and then the actions take place in other functions. That way each function can be tested on its own. The code in loop() could be reduced to this
Also, you seem to have lots of delay()s. A single interval should be sufficient to debounce all the switches. Look at how it is done in Several Things at a Time
The time to constrain the value, whether using constrain() or your (equivalent) method, is AFTER you increment/decrement the value, not before doing so.
Your programming logic is weird and your anti-bouncing delay duration lasts much too long:
delay(20);
Bouncing with mechanical buttons typically occur within one millisecond, so if you'd debounce for a 5 millisecond period should be enough.
If I were you I'd use a "buttonPressed()" function which returns true after a pressed button was detected and some logic like that:
static byte count=1;
static boolean countingUp=true;
if (buttonPressed())
if (countingUp) count++;
else count--;
if (count>=5 || count<=1) countingUp=!countingUp;
BTW: It's a shame that the Arduino platform comes along with big libraries for controlling complicated hardware like Ethernet or LiquidCrystal LCD, but for reading mechanical buttons the only library support is the "digitalRead()" function included in the Arduino core libraries.
jurs:
What about the Bounce2 library? Its a small library for controlling simple buttons.
speedCounter++;
Yep, that would do it.
Load this code into an arduino, look at the output, and try to grokk what it is doing wrong.
boolean goingup = true;
int speedCounter = 1;
Serial.begin(19200);
if (speedCounter <= 1) speedCounter = 1;
if (speedCounter >= 5) speedCounter = 5;
if (goingup) speedCounter++;
else speedCounter --;
Serial.print("speedCounter is ");
Serial.print(speedCounter);
if(speedCounter < 1) goingup = true;
if(speedCounter > 5) goingup = false;
jurs:
Unfortunately the library is a waste of RAM when using more than one button, because each button uses:
Well, you do need to keep variables for tracking pin changes, so I don't think there is all that much overhead in the little library. It scales nicely too, an array of buttons is easy as PI.
also, OP has SEVERAL delays in every call to loop() where (for primitive debounce) exactly one would suffice.
