Counting High Frequency Pulses
On the Arduino Uno timer 2 can be used to change the frequency while maintaining 50% duty-cycle, by utilising fast PWM mode with the double buffered OCR2A register acting as TOP. Double buffering prevents gitches in the PWM output when changing the frequency.
Here's an example of using the Arduino Uno fast mode to perform a PWM frquency sweep on pin D11 with 50% duty-cycle:
// Frequency sweep on timer 2 using output D11 with 50% duty-cycle
  Serial.begin(115200);                          // Initialise the serial port
  pinMode(11, OUTPUT);                           // Generate a square wave test frequency on D11
  TCCR2A = _BV(COM2A0) | _BV(WGM21) | _BV(WGM20);// Set timer 2 for Fast PWM mode with OCR2A as TOP
  OCR2A = 0;                                     // Set the OCR2A to 0
  TCCR2B = _BV(WGM22) | _BV(CS21);               // Enable timer clock without prescaler divide by 8
  for (int16_t i = 0; i < 255; i++)             // Decrease the frequency
    OCR2A = i;
    delay(10);
  for (int16_t i = 255; i >= 0; i--)            // Increase the frequency
    OCR2A = i;
    delay(10);
