create a connection between Arduino and a Webserver-folder
hello erveryone,
i want to download a txt-file from my webserver. DocumetRoot:
Webserver/website/test/konfig.txt
Therefore i need a connetion via...
EthernetClient MySystem_InitializeServerConnection(byte server[], int port, char location[])
EthernetClient ethClient;
ethClient.connect(server, port);
if(ethClient.connected())
// HTTP request:
ethClient.print("GET "); ethClient.print(location); ethClient.println(" HTTP/1.1");
ethClient.print("Host: "); ethClient.print(server[0]+'.'+server[1]+'.'+server[2]+'.'+server[3]);
//ethClient.print("hallo:$apr1$coV0b.4m$ljcI/p.auq.qn41K6VKaa1");
ethClient.println("Connection: close");
ethClient.println();
Serial.println("CONNECTED");
Serial.println("NO CONNECTION");
return ethClient;
The config is:
byte KonfigServerURL [] = {192,168,2,151}; // Konfigurationsserver, z.B. [www.MyWebsite.de] oder IP-Adresse (192.168.X.X für lokales Netzwerk), kein http:// angeben
char KonfigRelativeWebPage [] = "/website/TEST/Konfig-Blech.txt"; // Realtive Webseite mit Konfiguration: /Konfig-Blech.txt, /Konfig-Oberfläche.txt, /Konfig-Polen.txt
byte MAC_Arduino[6] = { 0x90, 0xA2, 0xDA, 0x0F, 0x9F, 0xE5 }; // MAC-Adresse vom Arduino
byte IP_Arduino [4] = {192,168,2,222}; // IP vom Arduino
byte SBNM_Arduino [4] = {255,255,255,0}; // Subnetzmaske für IP des Arduino
byte GW_Arduino [4] = {192,168,2,1}; // Gateway für Arduino
byte DNS_Arduino [4] = {192,168,2,1}; // DNS für Arduino
I don't get an connection!!!
please help. Thanks!
additionel:
in the folder above I have an .htaccess-file. i think i need an authentification sequence in the header. how should that look like?
P.S.: without the .htaccess-file it it will not work either
please help
Without seeing ALL of your code? Not much chance of that.
How is the Arduino connected to the internet?
Try this WebServer Tutorial and see if you can connect to it, so we can exclude internet problems.
The rest, as PaulS said, only posting your full code, because the error can, and normally is, outside the posted snippet.
