I really need 4 GNDs pins in my arudino and there are LOTS of alternativas in the internet and I found one very interesting: if I take a digital pin and do :
pinMode(4,OUTPUT);
digitalWrite(4,LOW);
People say this will make the digital pin 4 become a GND pin just like any other regular GND pin at arduino. Will this cause any problem to my arduino? Burn it in the long time?
It won't be a physical GND - there are some components inside the chip (which allow it to be Input or Output and in different states), between the input and 0V , they don't disappear when the pin is in LOW state -> your pseudo-GND won't be a good one
what happens if, by mistake, you put that pin in HIGH state in the sketch ? :o
What is your project situation? Using a 'breadboard' without power buses? (If so, just run a wire from GND to one of the breadboard rows - and you have 4 more Gnd points.)
[What's the market for a "Ground Shield"?]
batata004:
pinMode(4,OUTPUT);
Those people are wrong, you won't have anything like a good ground, and it will burn out if you
take any significant current.
Impedance between physical ground pins on Arduino - measured in fractions of an ohm,
impedance of an output pin - many dozens of ohms, limited to 40mA absolute max, or a fraction
of a mA if the Arduino is powered off...
Its not uncommon for people here to fail to understand the difference between a logic signal and
a power supply pin. ground is one power supply pin, a logic output is only for signalling or driving
light loads like one LED (some Arduino boards can't even drive a standard LED, though the Uno
and many others can).
Why not solder after twisting the wires? Soldering two wires together a is dead easy and can be done using even a garbage soldering iron (ie, the crappy non-temp controlled ones that trash circuit boards if you try to use them for board work - those are fine for soldering wires)
Maybe you can connect an adapter header thing to the ICSP port and create a heap of grounds from the GND pin of the ICSP port. There are TWO different ICSP ports (on UNO and 2560), each with a GND pin.
Or use strong glue to glue a 90 degrees header/connector to a sizeable blue area of the arduino board ....... use very strong sturdy glue. Or spot weld a metal casing to the side of the metal USB casing ..... and insert plastic header socket into the casing. And use that extra header for grounds.
